Sponsored by:
Sponsored by: CARiD
IH 1206 turbo diesel.
Old May 2, 2003 | 11:12 AM
dodgeman01's Avatar
I have a 1206 IH tractor that pushes 5psi of boots and pulls 15psi of vacume *sp. I got a cheap guage just to see how much Press. the turbo was pushing. From what I can tell it would run almost the same with a little hightr compreshion ratio and no turbo. Is there anythoughts to this?<br>DM01
Old May 2, 2003 | 02:23 PM
TxDieselKid's Avatar
Re:IH 1206 turbo diesel.
sell it and get yourself a green tractor!!!
Old May 2, 2003 | 02:42 PM
Ryan's Avatar
I would be happy to take it off of your hands. ;D I don't think it would fit in my garage but I would find a home for it. By the time I have a place to put a 1206 they will be so expensive that I won't be able to afford one. As for getting a green tractor thats the worst idea I've heard in a long time. ;D
Old May 2, 2003 | 04:44 PM
dodgeman01's Avatar
I bought this tractor three ywars ago and it has been a freat tractor but it does not pull as hard as our 666 IH which pushes 115hp on the dyno while the 1206 should push 112. I took the air filter off the tractor and the turbo has some slop in it but not a whole lot. I started it and held my hand infront of the turbo where the air comes out and goes into the intake for the engine and it pushed my hand away so I know it is getting boost from the turbo. I put is back together and put a guage where the port is for a boost guage on these tractors. Nothing over 3-5 psi even when pulling hard. When I back the throttle off all the way from WOT and let the engine stop me it pulls like 10pis of vacume. This does not make sense to me.<br>DM01<br>I bleed red and that is what my tractors are.<br>IH POWER
Old May 2, 2003 | 08:47 PM
P Kennedy's Avatar
&quot;Nothing Runs Like A Deere&quot; except a farmers cheque book at a parts counter covered in green and yellow parts. &quot;Green Things Grow In A Field&quot; not farmers and tractors. All turbo charged engines draw vacuum when not producing turbo boost otherwise they would not run at all. Naturally aspirated diesels usually are the same engines with lower power ratings with some internal differences. The 3-5 psi boost would have to be verified with the shop specifications, if boost is low many different things in the engine could be causing it. Signs of low boost would be excessive black smoke continously under load, plugged air filters, injection pump settings, loose connections/cracked gaskets from turbo to intake manifold, manifold to head gaskets, head gaskets, timing, valve settings and bad injectors. Some the older engines were not designed for high manifold pressures. PK
Old May 2, 2003 | 10:30 PM
NOTHING RUNS LIKE A DEERE!!!<br><br>Only thing reder then an IH, is a farmers face when he shows up at the Deere store, needing a REAL tractor. ;D
Old May 2, 2003 | 10:51 PM
dodgeman01's Avatar
I'm glad my Ih does not run like a deer. I would be dead on the roadside all the time. We have two big farmers that live around here together they farm 24k acres of land. Every tractor is red. o by the way we just bought a new Case IH Disc bine today. 10'9&quot; cutting width I think. can't wait to use it.<br>DM01
Old May 3, 2003 | 01:37 AM
P Kennedy's Avatar
OhOh somebodies Greene with envy, . Couldn't find the specs but some of those tractors had DT466 blocks so a lttle field bombing is possible. PK
Old May 3, 2003 | 06:44 AM
ScottB's Avatar
Sounds to me like your tractor is ready for a little more fuel. I hate to say this but whats the fuel filter situation. One more thing does it have a lift pump. I think that it could handle a little more boost. I wonder also what your egts are like, that would tell you a lot. Let us know what you find out.
Old May 3, 2003 | 07:01 AM
Mexstan's Avatar
Is there anything you bombing nut's will not try and bomb? :
Old May 3, 2003 | 08:15 AM
bulthisl's Avatar
A 1206 has a 361 cid. turbo <br>An 806 is the same engine only no turbo.<br>I've got a 806 with an after market turbo kit on it.<br>Runs like a scalded dog, it could stand an overhaul now days but it has served me well.<br>I will look up what the boost should be on a 1206. I should have it in a service book here somewhere.<br>Remind me with a pm if I don't get back soon.<br>I like the red ones better also. They are alot cheaper HP.<br>The green ones are good but that green paint is about $2000 a gal. It has to be I know the metal in them isn't worth that much. ;D<br><br><br> ; Eddie : 8)
Old May 3, 2003 | 08:19 AM
bulthisl's Avatar
Oh Yeah it's not any trouble to turn the fuel up a little on that Roosa Master pump. :<br>I have been known to play with them a little. <br><br>Who said that? <br><br><br> : Eddie : 8)<br><br><br>
Old May 4, 2003 | 11:08 PM
dodgeman01's Avatar
The tractor has 8k hrs on it :<br>DM01
Old May 5, 2003 | 12:16 PM
Hired Gun's Avatar
I have never run a 1206, but I am currently working on my 966. It has a 414 and now a new Turbo coming from Schied. I also had some pump work done. <br>Now she should pump an easy 125 after break in.<br><br>Of course, thats my little tractor. The 2394 turns 205 and isnt even huffing yet. <br><br>Red Rules!!!!!<br><br>Green makes a great set of plows and Hi-Boys though.<br>Tractors, well they quit making them with the 55 series. :'(
Ada381
Feb 10, 2008 07:58 AM
tfarmer96
May 4, 2005 09:59 AM
JoeDiesel
Mar 18, 2003 06:24 PM
