Sponsored by:
Sponsored by: CARiD
Hydroboost Pump
Old Oct 30, 2009 | 08:38 AM
Greguw's Avatar
Hydroboost Pump
Hey Guys , I am repowering a 1990 suburban , I'm going with a 1st gen 6bt , I am going to use a hydroboost set up since I am using 1 ton axles and brakes .
So I will not need the vacuum pump ... they allways leak anyway ... I know the 4bts came with just a pump set up , would the 4bt steering pump and mount work on the 6bt motor ?
Old Oct 30, 2009 | 11:56 PM
cbtumedic's Avatar
It should. If you can find a pump out of an old chevy p-chassis, or something similar it would be just right as I believe all of the diesel versions of those came with hydroboost.
Old Oct 31, 2009 | 06:32 AM
Greguw's Avatar
Is the P-chassis a full size tractor ?
Thanks
greg
Old Oct 31, 2009 | 08:36 AM
rbrettctd's Avatar
No the p-chassis is what gm used for the step vans and applications like that, it was just a chassis that the body makers put their own bodies on. Tons of them out there and they used to be available with a 4bt.
mtworks
Sep 9, 2012 07:11 PM
BrianW250
Jan 4, 2011 10:54 AM
1999blackcloud
May 14, 2010 01:57 PM
