Sponsored by:
Sponsored by: CARiD
How do u do a burnout with a 5spd?
Old Jun 13, 2007 | 08:12 PM
Box5's Avatar
With a auto it's simple, but how do u guys do a burnout with a stick? and how do u shift through it without the truck just taking off? I can't hold the brake, let out the clutch and hit the pedal at the same time, lol.
Old Jun 13, 2007 | 08:18 PM
BigBlue's Avatar
Rev the motor to 2500rpm, dump the clutch, then get on the brake and hold it just enough to keep the truck from moving. You could do it in 2nd gear and you should have enough tire speed to get the tires smoking good. 3rd would be a little to hard on the clutch to do.
Old Jun 13, 2007 | 08:34 PM
gyman98's Avatar
i always drive in 2nd then press the brakes and hit the smoke pedal at the same time and do a pretty good burnout. sometimes I'll just dump the clutch then hit the brakes too
Old Jun 13, 2007 | 08:35 PM
RickG's Avatar
Pour a can of 15W-30 on top of your rear tires .
Old Jun 13, 2007 | 08:36 PM
dieselJon's Avatar
I can do it in 3rd. With the 366 spring, I push the pedal about 3/4 of the way and let go of the clutch. I just did this last Saturday. Unfortunately, it was on tar but left 2 big black lines in it The thing that irked me though, I didn't realize that the tires were spinning until I let up on the go pedal. My bro was laughing because just as I let up he was saying something like "No smoke, but they are spinning"
Hope this helps,
Jon
Old Jun 13, 2007 | 09:54 PM
Muddin_dude06's Avatar
You have to "slip" the clutch if you do it in third, if you don't it will probably just die. 2nd gear is easy but doesn't get much wheel speed...
Old Jun 13, 2007 | 10:23 PM
Troutstrannysvc's Avatar
side step the clutch :P
or rev it and dump it like said above
Old Jun 13, 2007 | 11:27 PM
dodgezilla04's Avatar
get rolling slightly, turn up all the toys, and mash it in 3rd. when the turbo lights, look out tires....
works for me.
Old Jun 14, 2007 | 12:08 AM
dodgeguy71's Avatar
Right foot turned sideways with toes on throttle, heel on brake. Push throttle and brake at the same time, ease out on the clutch. Rpm drops, add fuel until you are rotating. I can get it turning pretty slow this way and then just ease into the throttle. I have never got my left foot over onto the brake. I dug a pretty good, well two good divets in the parking lot at the caddy dealer this way, hard on the tires though and I don't have $600 laying around for new tires so I try not to do it. It was fun while it lasted though!!!!
Old Jun 14, 2007 | 06:42 AM
Dieseldude4x4's Avatar
Step 1: push left pedal all the way to the floor
Step 2: push the right pedal all the way to the floor
Step 3: make sure the tach is on or past the red line
Step 4: put it in third gear
Step 5: side step the left pedal
Step 6: catch a ride to the parts store to buy new parts for the ones you just tore up
Next question:
Why would you want to do this?
Old Jun 14, 2007 | 08:43 AM
PoorMansCat's Avatar
step #1: right pedal on carpet Step #2: side-step left pedal Step#3: check rear view for dollar signs is smoke cloud
Wait, on public roads Step #1 is to look around for po-po first. The town I live in has a $20.00 per foot per mark + "exhibitation of accelleration" fine.
Old Jun 14, 2007 | 04:57 PM
bentwings's Avatar
Do you get a deal if it is with a dually?? Or do they multiply by 4???
Old Jun 14, 2007 | 06:03 PM
Box5's Avatar
lol ^. once it's time to buy some new tires, i'll post a nice burnout vid. I'm planning on some 35x12.5 tires with 2" spacers so no burnouts when I get those bacause there like $170 a pop.
Old Jun 14, 2007 | 06:23 PM
rbrettctd's Avatar
170 a pop? Lucky! I dropped that for my 265/75 BFG a/t's.
However, I run my old 235s for doing burnouts, plust they light a lot easier than these sticky allterrains.
Old Jun 14, 2007 | 06:35 PM
Psychobilly's Avatar
http://youtube.com/watch?v=6o6p1D28hVQ
http://youtube.com/watch?v=eVEBX5Qxm...elated&search=
Here's some good ones. (Niether are mine, I still need to sell my jeep before I get a 12v )
