How do 1992 & 2000 blocks compare?
Hey all, just wondering how close comparison on a 1992 block vs a 2000 block? Buddy needs a block, has a 92, can get a 2000, would it be useable? Other than the 24-valve setup(which is all to do with the rocker arms, isn't it), I can't see much difference. Any insight would be much appreciated! Thanks!!
, will have him check to be sure it is NOT!
Thanks for your inputs, have a good one!
heh heh, no he has a really worn-out 92, and apparently does have access to a supposed good 2000 block. I don't think there is any intent to build for power, just stock running specs. We were just wondering if the bare blocks are essentially the same to assemble/install, as all the right stuff seems to be there. In other words, we are wondering if anyone knows for sure if there is something that would PREVENT us from using a 2000 block in place of an original 92 block...clear as mud now?
Nope, they're different. I got a set of mounts for a 24v when I needed to replace one of mine and they were totally different... wouldn't even remotely fit.
I don't think the externals are different at all; I'm wondering about internals here folks, guess no one has had the experience with these motors?
Katmandu
Jan 16, 2006 08:30 AM
rzorko
Jan 17, 2003 08:22 PM
