Help with ID of Cummins Engine
I just bought a early to mid 70's Michigan 175a Front end loader with a inline 6 Cummins. It is also turbocharged. It also has only 1 cylinder head Does anyone know what sizes were used in machinery like this. Its a pretty good size loader, weighs about 14ton with attachments, and has air brakes.
Thanks
Thanks
I looked at buying a loader about that size several years ago and I seem to recall that it had a Cummins 160 in it. The one that I looked at had a bad waterpump that was no longer available from any source. I don't know if yours is the same but I seem to recall a motor ID plate on the right side of the loader motor.
It does have an ID plate, but no where does it list the HP rating, just the serial numbers.
Its an interesting water pump at least to me, I havent seen many with a grease fitting on the water pump
I have a 104b galion motor grader it has a 160 hp cummins but its not turbo, but if you have the serial # you can call 423-349-6111 and ask for parts tell them your trying to Identify the motor you have and If they ant real busy most of the time there very accommodating. It is Power Equipment a Komatsu dealer but I think many moons ago they were a Michigan dealer I think but want hurt to ask anyway. Hope this helps. Mike
Thanks
Thanks
gmccabejr
Oct 3, 2013 01:03 AM
ProjectM880
Dec 1, 2004 06:40 PM
