Sponsored by:
Sponsored by: CARiD
Heard A Rumour For 2005
Old Nov 7, 2003 | 03:08 PM
AlpineRAM's Avatar
Re:Heard A Rumour For 2005
BMW eliminated the throttle by adjusting lift of the intake valves and do timing by offsetting the cam in their new gassers. They stated that the technology of individual direct valve actuators is there but in terms of fuel efficiency theirs is better. With a cam you can recover the energy stored in the valve spring when closing the valve, with these actuators you can't.
Just my 2c
AlpineRAM
Old Nov 8, 2003 | 08:54 AM
Monty's Avatar
[quote author=Iron Horse link=board=8;threadid=21966;start=0#msg205650 date=1067988786]
I thought the new N14's and ISX engines still had cam actuated injectors with electronic timing?
I know for a fact that the 60 series Detroit is still cam actuated.
All the 3406 based Cat engines all run off the cam.
[/quote]
Yes, you are right. They are unit injectors (cam driven). The ISX (version of the Signature 600) is a DOHC design.
Scaling down this model for the Dodges? I would like to see that.
BTW..The agreement with Cummins being Volvos major engine supplier for there ISX engines is nearing an end. And, just in time to show off Volvos new D16C engine. It is an in-line six-cylinder with a displacement of 16.1 litres, available with a choice of two power outputs, 610 and 550 horsepower. This may have been the engine that your brother was talking about.
As far as a camless engine..CAT has expressed interest in this. I wouldnt be suprised if we dont see this design in the near future.
Old Nov 8, 2003 | 09:09 AM
HammerMTB's Avatar
[/quote]
You're right. The easy way to get high injection pressures is to use a cam to actuate, but use a solenoid to time/meter the fuel. This isn't likely to change for a while, and I would hazard a guess that the engine seen had cam-actuated injectors.
Old Nov 8, 2003 | 09:16 AM
Don M's Avatar
DTR Advertiser
5000 ft lbs equals everythig in the drivetrain broken within a few mintues. :'( Someone pulled yer leg....at least on the TQ.
Don~
Old Nov 8, 2003 | 09:29 AM
Scotty's Avatar
Top's Younger Twin
Don, with the right color of marker and some imagination one can have those torque numbers.
[quote author=Don M link=board=8;threadid=21966;start=15#msg207308 date=1068304608]
Don~
[/quote]
Old Nov 14, 2003 | 11:34 PM
kingofdodge7131's Avatar
Yeah the ISX has a dual cam, as far as an engine that powerful, possible. But From what i heard at a local fleet that uses kenworth( which has nuttin to do with this haha) that these engines might not be far off and are possible today if the manufatures wanted too, But one design they have to meet the 2009 standards is a Hydraulic drive, Using a smaller engine to run hydos to power the truck. Also using the same hydo to cylinders to stop the truck, making them into pumps themselfs and storing pressure in a tank and then using that pressure to also start the truck from a stand still. Sounds pretty promising. make mechanics jobs though!
Old Nov 15, 2003 | 07:07 PM
Badunit's Avatar
5000 ft-lb peak torque and 660 hp would require the peak torque to come in at 693 rpm or below (660 hp = 5000 ft-lb * 693 rpm / 5252).
Old Nov 19, 2003 | 09:25 AM
Dieseldude4x4's Avatar
I heard Chrysler is developing a gas turbine engine too.
Oops, flashbacks again.
Old Nov 19, 2003 | 09:56 AM
Commatoze's Avatar
[quote author=Dieseldude4x4 link=board=8;threadid=21966;start=15#msg211390 date=1069255534]
[/quote]
Anybody old enough to remember the Chrysler turbine at the 1964 World Fair in NYC? My recollection was that it sounded like an APU found in the tails of commercial aircraft.
http://www.moparstyle.com/turbine.htm
That was one cool car for a 13 year old to see and hear! EGT's? Can't even imagine!
Old Nov 19, 2003 | 10:57 AM
banshee's Avatar
EGTs on GTCs (Gas Turbine Compressors) are mild when compared to our standards. Most of our units today operate in the 1100-1200 degree range. Unfortunately they don't make any torque, so you have to rev 'em 50,000 rpms to make 100 hp.
John
Old Nov 19, 2003 | 12:58 PM
I remember the exhaust being a problem but I also rememebr them standing a nickel on edge on the engine while it was running. Cool..... Talk about turbo whine.......
Old Nov 19, 2003 | 05:33 PM
rjweiss's Avatar
Commatoze
The only thing I remember about the Worlds Fair was the Belgian waffles....ummmm
And my dealer heard rumors about a Cummins rotary diesel for 05 8)
Ron W.
Old Nov 19, 2003 | 05:47 PM
Don't forget, there is a hemi diesel out there too. :
Old Nov 19, 2003 | 09:06 PM
Holsteinman's Avatar
[quote author=Dieseldude4x4 link=board=8;threadid=21966;start=15#msg211621 date=1069285632]
[/quote]
Old Nov 21, 2003 | 05:01 PM
HOHN's Avatar
The F1 cars use a pneumatic valvetrain system, where air pressure both opens and closes the valve. At least I think so.
I would personally like to see if there's a way that the piston internal combustion engines in traditional configurations could use ROTARY valves. When it comes to efficiency, reciprocating is bad...rotating is good.
What if you had rotary valves all driven off little chains on the top of the head. If each valve had its own chain or something, you would have infinetely variable timing and duration.
Not to mention, no worry of grenading an engine from dropping a valve.
There's simply GOTTA be a better way to do things.....
Justin
