Sponsored by:
Sponsored by: CARiD
Fuel Shutoff Solenoid
Old Nov 6, 2006 | 01:32 PM
spitfire9137's Avatar
I have a Syncro Start Solenoid I am trying to troubleshoot on my generator. It has 3 terminals, a Pos +, a Neg -, and a Aux. What is this Aux terminal for? If I put power to it, it will pull the rod back just the Pos connection point, but the Pos point will work with a 10 amp fuse, when I do the Aux terminal it blows, 10, and 15 amp fuses and comes close to blowing a 20. What is this terminal for?
Old Nov 6, 2006 | 03:06 PM
ENGINENUT's Avatar
Syncro-start
There are many variations of the syncro-start arrangement and it's been awhile since I looked at a schematic, but I would take a guess and you can check it out.
As I remember the power requirement(amps)to pull in the plunger is a lot higher than to hold it in once it's there.When the plunger bottoms out it hits a contact that de-energizes the pull in windings so the amp load drops.I have seen this aux post used to energize something else when the plunger bottoms.One thing I remember is if the adjustment doesn't allow the plunger to switch off the pull in windings she will go up in smoke--shortly but not immediately.
Old Nov 6, 2006 | 04:23 PM
Ok I check on their website and see what I come with, thank you!
Old Nov 6, 2006 | 04:24 PM
XLR8R's Avatar
That is correct - on some solenoids, actuators etc. there are two sets of windings: one to move the load ("pull-in" or "open"), and another to hold in that position or state... sounds like the plunger is not reaching full travel or switching to the hold windings.
adamroofer25
Jun 24, 2004 05:54 PM
Palmetto_kid
15
Nov 17, 2003 02:47 PM
NOTSTK
Oct 7, 2003 09:13 PM
doomgaze
Feb 12, 2003 05:55 AM
RamTuffGirl
Dec 12, 2002 11:46 PM
