Sponsored by:
Sponsored by: CARiD
Engine Temps?
Old May 20, 2005 | 07:58 PM
CZSteve's Avatar
Engine Temps?
1st: I'm officially a diesel convert, I've seen the light.
I've had my '98 12v QC for about 6 weeks now and really enjoy driving it. I was a little concerned about the 5 spd during D/FW rush hour traffic, but I actually look forward to the stop-n-go as I enjoy 'rowing' the gears.
Questions: (forgive, I'm still a newb)
I've been under the impression that a diesel will disipate engine heat better than a gasser (ie: less of an issue of overheating while idleing).
Is this true? And if so, Why?
You would think the opposite would be true w/ the higher compression ratio.
I plan on getting a pyro & boost guage and I'm aware of keeping an eye on the EGT's. But, can I idle safely during Texas August heat? The temp gauge reads a constant 180-185 so far.
What's the ideal range for these motors?
Old May 20, 2005 | 10:31 PM
BlueDually's Avatar
they idle cold all the time, extended cold low idling will kill the cummins, whenever i idle mine, its fast at -40 or +100f, 1200+,
not during a few minute warm up, or cool down
Old May 21, 2005 | 06:28 AM
Diesels cool off at idle better because there is no throttle restricting airflow through the engine. Also there is less fuel being burned, meaning less heat being generated.
Idling in traffic with the A/C blasting isn't going to hurt it. Between the load from the A/C and the heat outside, the inside of the engine will stay warm enough. What you want to watch out for is extended idling in conditions that let the EGT drop below 250 degrees (like cold weather).
Old May 21, 2005 | 09:29 AM
Mopar1973man's Avatar
Just keep the EGT temp up above the 250 mark your good... If I'm going to sit in traffic I will throw on the jake. It will kick the EGT back up to 400*F easy! I can idle all day with that...But I wouldn't do it...
cLAYH
May 25, 2006 06:40 PM
ellerman
Jun 9, 2005 09:36 PM
angleiron
Dec 21, 2004 01:13 PM
rico334
Oct 27, 2004 06:49 PM
something87
Aug 25, 2004 04:54 PM
