Engine came to life today... pics...
Finally was able to get the new engine ready to start today. Fired right up and sounds good
I should have an A/C compressor next week so I can put the belt on it (to run the water pump) and let it come up to temp. I need to bring it to temp a few times so I can retorque the head studs before I install it in the Excursion.
In the meantime, I need to get the billet input shaft installed in the trans as well as some other required tranny upgrades
Here's some pics...
I should have an A/C compressor next week so I can put the belt on it (to run the water pump) and let it come up to temp. I need to bring it to temp a few times so I can retorque the head studs before I install it in the Excursion.In the meantime, I need to get the billet input shaft installed in the trans as well as some other required tranny upgrades
Here's some pics...
I let it run in the garage for now. I'm picking up a stock exhaust clamp so I can hook up some exhaust pipe I have laying around to get exhaust out the garage. (EDIT) just got back from the dealer, they want $64 for a clamp between the elbow and the downpipe
I guess I'll go ahead and put the SPS62 on it now (I do have a downpipe and clamp for it)...
It came on the wooden engine stand. (engine is new)
engine mounts from autoworld, throttle cable adapter from Destroked, transfer case input shaft from transfercaseexpress.com, most other parts from a salvage yard, performance shop, or classifieds...
I guess I'll go ahead and put the SPS62 on it now (I do have a downpipe and clamp for it)...It came on the wooden engine stand. (engine is new)
I'd suggest that you mount some air filter on the intake as long as you don't have your CAC piped in (Won't need that on the test stand)- it's nice that you filter your turbo but the engine gets to eat all the dirt..
Cool project!
AlpineRAM
Cool project!
AlpineRAM
I'm not a Ford fan, but an Excursion with a CTD is awesome. I've always had that idea jumping around in my head, and I haven't seen anyone attempt it until now. If a CTD can be put into a F250 or F350 fairly easily, why not an Excurion? I'm extremely jealous, and I'm not the jealous type.
I mainly have the air filter on the turbo to keep one of my kids from putting something in there without me knowing about it. I also have a cap to close off the intake horn when it isn't running. I was trying to see how easy it was to kill the engine with a block of wood to cover the intake horn (pretty easy, doesn't take much at idle anyway). I'll be working on a emergency air cutoff for my pulling truck this winter.
I like the idea of keeping the manual fuel switch as well as some others...
Got the billet input shaft installed today on the 48RE, as well as an upgraded band, hd strut & lever, and ATS valvebody. Working on the overdrive section later this week.
..... I was trying to see how easy it was to kill the engine with a block of wood to cover the intake horn (pretty easy, doesn't take much at idle anyway). I'll be working on a emergency air cutoff for my pulling truck this winter.
Getting ready to swap the billet input shaft (stock on left, billet on right).
Waiting for a new overdrive housing so I can swap all the internals over (my rear case is cracked). Should have it from Goerends later this week.
