Detroit 2 stroke 4 cylinder
ya too bad it went into a class 8 GMC General tractor, that was sooooo beat down it wouldn't pass CVIP so it was relegated to a yard truck..............AND then they dusted that engine 2 weeks after they got it
Detroit 2 strokes are extremely easy to work on. DD has some of the best manuals available for doing repairs. It could be fun. But it would need to be very cheap. I love the sound of a screaming Detroit.
Here is the deal: I went and looked at the truck yesterday afternoon. It is a 78 Chev 3/4 ton. The cab is pretty clean, the frame is pretty clean, and the guy that has it now just put a different box on it. Overall it is in fair shape. It had been used for plowing snow the last 15 years, so it has a plow on the front and a sander in the box. Both would be junked because they don't work anymore. It is a non-turbo, 4 cylinder Detroit. On the left side of the engine there is a cover that says GM diesel. The only thing I could read on the engine plate was 5129805. It has a 5 speed manual out of something, and a divorced transfer case. Both the front and rear axles looked pretty small for a 3/4 ton. It has a pretty big suspension lift with 38-15.5-16.5 ground hawg tires. The tires are bald, but I have a set of 40's that I could throw on it. I am pretty sure I could get the truck for a couple hundred bucks, but I don't know if I will be getting myself in over my head. What do you think, should I get it?
It's hard to go wrong for a couple of hundred bucks. If you decide to bail out later, you could probably sell it for scrap iron and get that much. Where are you located? If you don't get it maybe I can come and buy it.
Actually it is a supercharger, because multi cylinder two stroke engines with a common plenum chankcase have to have positive pressure on the inlet or the cylinders wouldn't fill.
In its design application on the -53, -71 and -92 series Detroit Diesels, it's a scavenging air blower. It's not a supercharger. By engineering definition, for it to be a supercharger, cylinder air pressure at the beginning of the compression stroke has to be significantly above atmospheric pressure - this isn't the case. The blower just moves scavenging air through the cylinders since the 2-cycle engine does not have an exhaust or intake stroke.
Rusty
Rusty
Rusty
Rusty
