Sponsored by:
Sponsored by: CARiD
Cummin's pistons
Old Aug 4, 2003 | 08:13 PM
4x4's Avatar
4x4
Cummin's pistons
I have seen diesels with steel pistons, aluminum pistons, aluminum pistons with a steel crowns, but what are our truck's made out of?
4x4
Thanks for the help.
Old Aug 4, 2003 | 08:43 PM
4x4's Avatar
4x4
Re:Cummin's pistons
I'm thinking aluminum ???
4x4
Old Aug 4, 2003 | 09:38 PM
Re:Cummin's pistons
You're thinking right. Just aluminum, no steel.
Old Aug 4, 2003 | 09:46 PM
4x4's Avatar
4x4
Re:Cummin's pistons
Thanks.
4x4
Old Aug 5, 2003 | 01:51 AM
DieselDaze's Avatar
Re:Cummin's pistons
I believe the pistons are aluminum.
That is why the max temp is somewhere around 1350* for no more than 30 (or so) seconds.
Anything more than that, and you will find out what the pistons are made of first hand.
Rich
Old Aug 5, 2003 | 05:55 AM
Dieseldude4x4's Avatar
Re:Cummin's pistons
It's called molten aluminum at that stage or thereabouts.
Old Aug 5, 2003 | 06:01 AM
DieselDaze's Avatar
Re:Cummin's pistons
;D
Rich
Old Aug 5, 2003 | 04:48 PM
routerguy99's Avatar
Re:Cummin's pistons
So if cummins puts aluminum pistons in there engenes, and GM uses aluminum heads , why do the heads fail on the GM ? and so why dont we see cummins pistonn fail becouse they are aluminum ? this does not make sence to me.. am I being stupid.
Old Aug 5, 2003 | 05:58 PM
Re:Cummin's pistons
Ditto to what Gary said. Cast iron pistons are too heavy, they went out in the '30's. Steel topped aluminum pistons have been used in some diesel designs to allow higher cylinder pressures and temperatures, but they have to run at lower speeds due to the extra weight.
The way expansion is dealt with in pistons is by making them slightly out of round and also slightly tapered when cold, so they expand into shape at operating temperature. One more reason not to flog your engine until it's warmed up.
Old Aug 6, 2003 | 09:49 AM
Re:Cummin's pistons
[quote author=wannadiesel link=board=8;threadid=17976;start=0#msg168628 date=1060124336]
[/quote]
Thanks I get it now
DodgeRam24V
13
Oct 27, 2011 11:28 PM
RollinCoalSmoke
May 29, 2009 09:20 PM
skynyrd
Jan 10, 2008 06:41 AM
ddestruel
May 10, 2005 12:17 AM
Iron Mike
Oct 17, 2003 12:15 AM
