Sponsored by:
Sponsored by: CARiD
CTD 5.9 ISB & Allison
Old Oct 16, 2005 | 01:47 PM
10-9jc's Avatar
Just an observation for "discussion" -
Cummins and Allisons are "mated" in lots of applications,
but this is interesting for possible "conversions"? -
[the trans and adaptor?], and . . .??
From page 18 of the Nov. issue of Trailerlife:
"Tiffin Motorhomes has introduced a FRONT-engine diesel among
it's 2006 models, with Freightliner producing the chassis.
The 22,000 to 26,000 pound GVW chassis features a 300+ HP
5.9 liter Cummins ISB engine and an Allison 5-speed transmission".
JC
Old Oct 16, 2005 | 04:02 PM
rammtuff's Avatar
JC
I suspect this application would have a different cam profile, different torque curve to work with the allison trans.
Nothing new. Buddy of mine has a motorhome 5.9 ISB with an allison.
Old Oct 16, 2005 | 06:27 PM
Begle1's Avatar
Well, we can fix the cam profile and torque curves...
Is this the Allison from the Chevy and GMC trucks? If so, then all you'd need is the adapter?
Or would you need a ton of electronic gadgets for it too?
Old Oct 16, 2005 | 06:51 PM
10-9jc's Avatar
Rammtuff - is your friend's motorhome a Class A - non-Pusher?
Just curious, 'cause to the best of my knowledge front eng Class A
chassis (until now) are only Ferd or GM (gas) powered . . .
Seems your friend's MH [Class A or C] would have to be a Dodge.
Don't follow MH's too closely, so fill me (us) in.
Begle1 - I was wondering the same thing - same Allison as
used w/Duramax? And, oh yeah . . .the electronics ???
Superduty are you out there? Johnny 5 needs Input!
JC
Old Oct 16, 2005 | 08:28 PM
G1625S's Avatar
What would be different about the cam profile? MORE low end? I could live with that. More top end? I could live with that, too. Sounds like a swap worth looking into, to be sure.
g
Old Oct 16, 2005 | 10:28 PM
Smkndzl's Avatar
The truck ISB come with the World trans. in them.... also I dont believe they are OD. final ratio is 1:1 .
Old Oct 17, 2005 | 12:56 AM
Bluedeviltorque's Avatar
I would think that if this was a viable conversion there would be many of them done already. But who knows, maybe someday dodge will have an auto that will actually be able to put the power to the ground...
Mike
Old Oct 17, 2005 | 07:31 AM
Dr. Evil's Avatar
Does anyone have info on an Allison conversion??
Is the HD parts available for the Allisons??
I may have access to one for $1500...
Old Oct 17, 2005 | 10:01 AM
John Faughn's Avatar
I've been looking at this for a while , I do not have a lot of info at my finger tips but some general stuff I've seen here and TDR some with pic's showing the installed Allison , most were Allison 1000 with a seperate box for electrical control, the older non computor control like the 5spd. with out overdrive also. My end result is to put less money in my stock trans. is just as good as an Allison -at least thats what the others that have gone down that road have said . I think that if I had access to a used 1000 for free to cheap then build it myself, then that would save $$ and I might go that way.
Old Oct 17, 2005 | 09:48 PM
gerry's Avatar
My Freightliner has an Allison 6speed behind a Cummins 5.9.
I spoke to the Fleet mechanic and asked him what it would take to put that in my truck.. His answer was a lot of sheet metal cutting... The transmission although would mate up would be to large for a pickup..
Not sure which trans is in there but it works good stays around 210 degrees no matter how big the hill is while pulling 25K to 30K without a trailer.
It also has 2 PTO's on it .. one for a compressor and 1 for the Backhoe.
Old Oct 18, 2005 | 04:56 PM
Monty's Avatar
Most of the Allison transmissions in Freightiner RV's and business class trucks are 2000 series and 3000 series. You will find quite a few manual 545P Allisons in the small, older, utilimaster step vans that UPS, FED EX and bread trucks use.
dieselfuelonly
Jan 26, 2007 11:11 PM
Mark Hodowanec
Dec 29, 2006 02:49 PM
BrewPub
Jun 15, 2006 08:30 AM
BobQ
16
Mar 20, 2006 04:09 PM
possum
May 24, 2005 11:30 AM
