Sponsored by:
Sponsored by: CARiD
Cool block heater cord!
Old Sep 30, 2005 | 12:43 PM
redneckonthenet's Avatar
Check out this block heater cord.
http://www.arcticleash.com/index.html
Old Sep 30, 2005 | 01:14 PM
Eskimo's Avatar
Uh, ok.. $99 for a decent (but short) extension cord on a wind up reel.
I don't get it. What's the big deal?
Old Sep 30, 2005 | 01:23 PM
P.J's Avatar
P.J
It IS cool if you do the permanant install in the engine compartment.The pole mount model is just a glorified extension cord you can get a Sears. This way you just reel it out every night, no extension cord to fool with.
I use a 6 foot heavy duty jobber because I park right up close to a GFI on the outside of the garage. (no need for the fancy retracto-reel)
Old Sep 30, 2005 | 02:35 PM
Hillbilly_Deluxe's Avatar
Whats wrong with extension cords?
Old Sep 30, 2005 | 03:57 PM
Shovelhead's Avatar
Administrator / Scooter Bum
Some have tried the wind-up reels before, and found the heat generated by the high amp load of the <edit>Block heaters got captured by the windings of cord in the housing and the housing itself causing a melt-down.
Old Sep 30, 2005 | 07:30 PM
rammtuff's Avatar
Some have tried the wind-up reels before, and found the heat generated by the high amp load of the grid heaters got captured by the windings of cord in the housing and the housing itself causing a melt-down.
*scratches head*
You need an extension cord for your grid heaters? Man you must have alot of cords.
Mine run off the batteries.
Old Sep 30, 2005 | 07:46 PM
infidel's Avatar
Ed is right.
Most of the self retracting reels say right on them not to use unless totally unwound.
I took a chance once with one and had it meltdown, thank someone for circuit breakers!
Old Sep 30, 2005 | 08:53 PM
Nvisable's Avatar
If these are the same ones i've seen reviewed on TV, they claim it won't jam or freeze. If it's not then forget what I just said.
Old Sep 30, 2005 | 09:03 PM
RATTLINRAM's Avatar
Originally Posted by rammtuff
*scratches head*
So that's why Ed always starts up that gas powered generator he hauls around in the back of his truck before he cranks the truck motor. I'm glad my grid heaters run off the truck batteries like rammtuff's also!
Old Sep 30, 2005 | 09:29 PM
Shovelhead's Avatar
Danged rented fingers...........
Thanks..
Old Oct 1, 2005 | 01:41 AM
durasmack's Avatar
gettin to be bout that time of year again that the snakes come out....... the orange and black snakes.... yea you know the ones.... the ones that follow you all the way to work.....
Old Oct 1, 2005 | 06:38 AM
Holsteinman's Avatar
The key to keeping that from happening is to unplug the truck before you start it. That is what you should do anyway.
Old Oct 1, 2005 | 08:02 AM
jrs_dodge_diesel's Avatar
One trick I learned to prevent the orange or black snake chasing you down is to wrap the cord around the drivers side mirror if you can. ALMOST guaranteed not to forget it.
Old Oct 1, 2005 | 08:18 AM
PistolWhipt's Avatar
Pretty bad that there are so many of us that have been chased by them snakes.
Kinda like the fat gal coming out of the bathroom with her dress stuck in the back of her panty hose !!!
PISTOL
Old Oct 1, 2005 | 05:38 PM
turbox2's Avatar
HMMMM Note to myself Buy extra mirrors
