Sponsored by:
Sponsored by: CARiD
controal panel
Old Oct 2, 2010 | 10:34 PM
Tammy's Avatar
controal panel
Need help
We were on a trip today and the drivers turn signal started flashing very fast. Keep in mind no trailer this trip just empty truck. When you trun it on it flashes normal about 4 time then gets faster.
I checked it at our first stop and the light in the rear will work while it is flashing normal but will not when it speeds up.
Then if that aint enough the wife got the keys from me and got in the truck to get the camera and then I went back to move the truck later and the **** key fob would not open the doors. I used the key to get in then started the motor it would run for a secon then die it did this several time. I used the inside door locks to lock and unlock the doors then it started and ran, what the hell this is getting weard
The truck ran fine all the way home 225 miles but turn signals ar still mesed up, I supect the new controal center fuse box they installed less than 2 months old?
Richard
Old Oct 3, 2010 | 07:48 AM
Hvytrkmech's Avatar
The directional issue could just be a bulb with an intermittent fail. I would throw a light bulb at it first. I have had the same issue with my fob key, just put the key in the door and lock and unlock it, then all will be normal. New battery in the key fob no issues since.
Old Oct 3, 2010 | 11:20 AM
.boB's Avatar
A bad ground or dirty socket can do the same thing.
Jul 3, 2003 10:52 AM
mdq
Jun 23, 2003 07:07 AM
pappygtb
Mar 7, 2003 08:28 AM
Ghostrider
Jan 5, 2003 01:19 PM
