Chirp gone?
Chirp gone?
After I had my puke bottle removed and the hose extended down and to the center of the truck to puke all over my driveway, my chirp has just about vanished. Once in awhile I will hear a very little chirp, but most of the time it just shuts down nice and quiet.... anyone else's chirp go away after bottle relocation/removal? ???<br><br>Tony
Re:Chirp gone?
I've heard of a rare Tony bird nesting in those thar bottles.
Actually it is probably that you do not have your climate control set on the defrost combinations and are sending heat to the floor. The AC compressor does engage with defrost and a few other settings on the dial. Whenever I have my heat blowing on the windshield it gives the chirp...unless the belt is really cold, then it will not chirp.
With Tony, its probably a bird and still chirping but out of his hearing range. quack quack
Re:Chirp gone?
[quote author=Cattle Hauler link=board=8;threadid=7818;start=0#74987 date=1038923698]<br>My chrip just stopped, wonder if my belt is getting worn?<br><br>I have not relocated the bottle either.<br>[/quote]<br><br>CH, If your truck is like my 99 then you don't have a bottle just the hose that points down to the steering box, and makes you think you have a big power steering leek. :
<br><br>Watch that belt fellas, I replace mine every 20k. If you take the belt off and put it in your hand and sqeeze it together and see more than 20 cracks per inch then it should be replaced. I think mine run about $30 from Cummins. They usually look pretty bad after 20k miles. So if you're still on the original it's a ticking time bomb.
<br><br>DB
<br><br>DB
Re:Chirp gone?
[quote author=Cattle Hauler link=board=8;threadid=7818;start=0#74987 date=1038923698]<br>My chrip just stopped, wonder if my belt is getting worn?<br><br>I have not relocated the bottle either.<br>[/quote] <br><br><br><br> CH, Are you still running the belt that came on the truck? Just currious. I have 43k on mine, guess I should change it.
Re:Chirp gone?
Mine vanished for about a week.<br>Then came back.<br>Sometimes it chirps, sometimes it doesn't.<br><br>Tried to determine the factors in play when it does and compare them to what was going on when it doesn't and came to the following conclusion.<br><br>I HAVE NO IDEA. ???<br><br>Seemed to chirp more when AC was on prior to shutting down,<br>sometimes, that's counting the defrost/defrost-floor AC cycles.<br>But, still, sometimes it doesn't chirp with AC on.<br><br>Seems to be able to sense when someone is walking in front of the truck, and almost always chirps then, resulting in a glare from said person. :
<br><br><br>phox
<br><br><br>phox
Re:Chirp gone?
[quote author=phox_mulder <br><br>Seems to be able to sense when someone is walking in front of the truck, and almost always chirps then, resulting in a glare from said person. :
<br><br><br>phox<br>
Re:Chirp gone?
[quote author=TPilaske link=board=8;threadid=7818;start=0#75924 date=1039069510]<br>Ummm... disregard this post - the chirps back! ;D
No clue why it didn't chirp for like a week?! ???<br><br>Tony<br>[/quote]<br><br>Probably had something to do with the salt on the roads.
TAMU
May 27, 2009 06:34 PM
TAMU
Apr 27, 2009 11:26 AM
