Sponsored by:
Sponsored by: CARiD
case skid steer with cummins??
Old Feb 21, 2007 | 12:16 PM
Iron Mike's Avatar
Originally Posted by JKM
Way off topic, but is that a David Brown I see hiding in the background?
Old Feb 21, 2007 | 03:57 PM
JKM's Avatar
JKM
Originally Posted by Adam3291
4th gear on the Powershift. Its completely gone, tractor will come to a dead stop.
Does it lock up , or roll to a stop like it was in neutral? Next time you try it , step on the clutch , and count the number of times the trans light flashes , IIRC it only goes up to 6 or 7 flashes. There should be a page in the owners manual giving you the reference for the # of flashes , if not, let me know and I will check my book , it will really help narrow things down. It might be a really cheap fix.
Old Feb 21, 2007 | 04:04 PM
JKM's Avatar
JKM
Your darn right it is , that is my favourite tractor ever, It is the first one dad ever bought , right after he bought the farm , and it is the one I learned to farm on. 1974 ( as near as I can figure out) David Brown 885 , with a David Brown factory loader. IIRC right around 5400 hours , still runs good , starting to smoke a little though. We don't use it very much any more , but I still love it. Dad talked about selling it this spring , actually trading it in, I put my foot down and said no way, I am doing a full restoration on it this summer , right down to the lights that USED to be on the fenders of all those tractors.
Old Feb 21, 2007 | 04:09 PM
Adam3291's Avatar
Rolls to a stop, I'll try it next time I use it but I'm pretty sure the trans light doesn't come on when I go into 4th on the Powershift.
Old Feb 21, 2007 | 04:25 PM
JKM's Avatar
JKM
It will be the one on the far left of the dash , i can't remember if it says "check trans" or if it is the clutch dis-engage light. when you shift it into 4th , the light should come on , then step on the clutch , and hold it down until the light stops blinking , and count how many times it blinks.
Old Feb 23, 2007 | 12:43 AM
ckt_santiago's Avatar
Yes it was a 4BT... Case IH is no more; Case New Holland is the new company... That is why they switched power plants. Personally I am looking closer at the new McCormicks. They are the EXACT same tractor as the old magnum series just that the smaller ones are Perkins powered; cummins power comes when you get above 90hp.... 90-135 ISB 90-270 ISC and I would only assume that their new articulators rated at 300+ are ISX powered. We have nothing but International/Farmall tractors on the farm so that's what I am partial to and as an Ag Mechanic I can say that I like the way the IH's are put together.
On another note, a buddy of mine found a burnt up 1840 skid steer and is gonna steal the engine so we can drop it in his 95 S-10 Blazer
Old Feb 23, 2007 | 06:37 PM
Adam3291's Avatar
I had a chance to check it today. Shift into 4th on the Powershift and the tractor roles completely to a stop. No warning light comes up on the dash. I know it works because I put the tractor in 4th gear and put the shuttle in reverse and the light came on like it is suppose too. So I believe what my bossman told me in the past, it will be an expensive fix.
Old Feb 23, 2007 | 09:23 PM
JKM's Avatar
JKM
Ok , I am going to check my book tomorrow if i get a chance , and I am going to get you to try something and see what happens, What I will get you to do , is swap the wires for 3rd and 4th gear selonoids , so when you place the gear selector (power shift) where 3rd would be , it will be in 4th , then let the clutch out slowly and see what happens, this would rule out an electronic problem, although it is actually sounding like maybe there IS something mechanically wrong inside...
mini14
Aug 18, 2013 08:19 AM
Timberman
Jun 14, 2006 08:10 AM
Timberman
Apr 24, 2006 10:23 AM
pappyman
Mar 11, 2005 12:46 PM
96_12V
May 28, 2004 11:55 PM
