Sponsored by:
Sponsored by: CARiD
Autozone
Old Aug 29, 2005 | 07:30 PM
wadel1's Avatar
Question Autozone
I have read alot of comments about Autozone being referenced as the place to go and get your engine codes read and/or cleared. Maybe I am a little confused but the only Autozone I know of is a part store...is this the same place or and I confused?
Thanks for my silly question.....
Old Aug 29, 2005 | 07:36 PM
HorseHauler's Avatar
same place, local autozone here advertises about checking codes for engine light troubles
Shovelhead's Avatar
Administrator / Scooter Bum
The "Parts-Looker-Uppers" at AutoZone, Advance Auto Parts and I think Pep Boys (among others) have a low-buck code reader that can only access/clear some codes. They'll come outside to your vehicle and plug in to see what shows up.
Old Aug 29, 2005 | 07:37 PM
partytyme's Avatar
same place they will pull the codes for free
Old Aug 29, 2005 | 07:49 PM
ftltmp's Avatar
You can ask too borrow the reader and you can walk out and check them and clear them yourself, they will not clear them for you, because people were coming in and getting codes cleared and then taking it up the street to have an inspection done , and when they would check them it would come up as codes cleared , and then mech would ask who cleared codes ? then they would tell them autozone. Then they will make you drive it 1500 miles and come back again to have it insp.
Old Aug 29, 2005 | 07:53 PM
wadel1's Avatar
Codes...
Once I get the codes out of it where do I get the cross reference of the code to the symptom?
Old Aug 29, 2005 | 08:04 PM
Shovelhead's Avatar
In our Tech Facts section accessed by clicking on the button in the site header.
https://www.dieseltruckresource.com/...n&onlynewfaq=1
Old Aug 29, 2005 | 08:21 PM
Fronty Owner's Avatar
The code reader they use here will tell you what it means.
Old Aug 29, 2005 | 10:33 PM
dslchk_cowgirl's Avatar
wade1 .. what kind of truck do you have, year etc .. on some trucks you can pull the code by turning the key a couple times
Old Aug 30, 2005 | 12:50 AM
wadel1's Avatar
Truck
I have a 99 Dodge SLT 4x4 Club Cab Diesel. Would be awesome if that is possible. Hey I thought when the Check Engine light was on it would start on but mine is on and then a day or so later it will be off......
Thanks!!!
Old Aug 30, 2005 | 07:35 AM
P.O.R.'s Avatar
all codes will still be there untill some one clears them, even if the check engine light is on then off.
Old Aug 30, 2005 | 09:00 AM
CTD NUT's Avatar
Re: Truck
Thanks!!!
Your 99 does not have key on-off code display feature that the 00 and later CTD's have.....if you had a check engine light come on at any time, there will be a code stored.....
Old Aug 30, 2005 | 09:09 AM
Mcmopar's Avatar
Some codes get stores and no light comes on also.
Old Aug 30, 2005 | 10:18 AM
crobtex's Avatar
Some codes clear themselves. I believe they're called "demand codes" and will clear themselves after X number of starts/key on or whatever. The ones that cause the lights to stay on are "set codes" and require a scan tool or repair to clear them.
If your light comes and goes, you probably have a "demand code" caused by a re-occuring problem. Reading the codes when the light is on is your best bet to find the problem.
Old Aug 30, 2005 | 10:41 AM
wadel1's Avatar
List of Demand Codes?
Is there a list of what might be a demand code vs a set code? Just wondering.....I am fairly sure that this is related to the issue I am having with my temp guage sometimes working and sometimes not. The problem is that there are times when the guage is not working and yet the check engine light is not on.........
