Sponsored by:
Sponsored by: CARiD
Any Electrical engineers out there? I want to build a homemade chip.
Old Aug 24, 2010 | 05:02 PM
peanut's Avatar
I took a few electrical engineering classes in college and know just enough to get me in trouble. I know that the major part of an edge ez or bully dog is simply a resistor, or in the more expensive models a potentiometer.
I am sure this question has been asked before....Why cant I splice the mapp sensor wire myself and put a potentiometer inline? more resistance means the engine sends more fuel. easy right? lol I know, i know its never easy.
I think someone told me a while back - "its because the chips are timing boxes as well".
this is where i say..."huh?"
this theoretical chip would be mounted on my 24 valve cummins 2000 model.
Im sure it has been discussed but I cant find the thread.
Old Aug 25, 2010 | 06:44 AM
1-2-3's Avatar
Just a plain ole guy
there's more than just one thing going on at a time. Changing one things puts things out of order. You have to change all that's needed. There's a guy here a while back cracking ECM's open and figuring out how they tick. You might try some searches and see if you can find that and follow what he's doing.
Old Aug 25, 2010 | 08:08 AM
patdaly's Avatar
Here's a couple:
https://www.dieseltruckresource.com/...u-t169965.html
https://www.dieseltruckresource.com/...hlight=ECM+map
Old Aug 25, 2010 | 11:41 AM
AggieJustin's Avatar
If you just want to alter the boost signal, then you can put together the right combination of components to change what the ECM is seeing from the MAP sensor. But small boxes like the EZ or Bully Dog do more than just play with the boost signal. They have a boost fooling function built into them, but they also plug into the Data Link connector to communicate with the ECM to alter the timing and fueling parameters. If you step up to the larger boxes, they also tap into the injector pump solenoid wire to push more fuel than what is possible through the ECM.
If you just trick the ECM into seeing more boost than what is really there, you're really just making a more complicated "smoke switch".
Old Aug 25, 2010 | 09:02 PM
BullyDogJason's Avatar
Im not an engineer or anything.. but i do know there is more to our chips then just some resistors. there is microchips that we burn data to.
Mexstan
Dec 18, 2009 07:10 AM
Fronty Owner
Feb 15, 2007 10:21 PM
billygoat02
Jan 9, 2007 09:32 AM
99DodgeGuy
Nov 15, 2006 05:26 PM
