Added first 1qt of 2-stroke
Originally Posted by robert chilton
burning waste oil mixture 1-4 gallons depending how much I have on hand. You shouldnt really notice it smelling to you get over 5% and that is when the motor is cold. The odor and haze from high mixtures will go away with more boost. .
And if the waste oil is not clean by the time the injectors see it won't that cause undo wear on the orifices?
Big Jimmy
UPDATE!
As of today, Wed 3/1/06, so far so good. I have 264 miles on a 1/2 of a tank of fuel, (60% highway,40%town) smoother idle, engine rattle is quieter, not as tiney sounding, truck seems very happy with the added 2-stroke oil.
Truethfully I am not not worried about the injectors. They have 240k on them. But I drain the oil into an clean drain pan then filter it into gallon jugs. Once its in the jugs it has time to settle the solids before it goes into the tank. Once in the tank you have the prefilter on the fuel heater and the fuel filter to get anything else that makes it that far. I am sure some really small junk gets past it and makes its way through the injectors but you get the same from the fuel tank at the gas station. Just think of all the gunk that gets knocked into the tank when the trucker refills it. Basically it boils down to does the end justify the means. Less fuel being bought to drive, better lubing of the fuel system, equal to better MPG at under 10% mix, and it saves me from going to the auto parts store out wiegh the chance of some injector wear.
I timed my injector pump the other day and I didnt see anything reflecting light like metal flakes inside the injector pump floating in the fuel. I also didnt see any scuffing or shiny wear marks on the delivery valve assembly. I have been running WO for about 10k miles in the truck with anything between 2 and 15% ratio. 2 gallons per tank seems best for less smell and good power. Guess it is working so far.
2 Stroke
I initially added 16 oz of Wallyworlds 2 stroke oil with TCW3. At every refill (usually 10 to 12 gallons), I add 8 oz.
No more injector rattle on accelleration. The quietest I've ever heard.
Originally Posted by Rick D
At $15.00+ a gallon for TC W3 and $30.00 plus for the synthetic, i can't see alot of savings using either one.
Rick
Rick
MikeyB
Ditto here, I paid $2.13 for a qt. of Pennziol TCW-3 outboard oil. Which I know is not the cheapest. And for the record 2-stroke oil is made to burn in an internal combustion engine so no worries there.
At $15.00+ a gallon for TC W3 and $30.00 plus for the synthetic, i can't see alot of savings using either one. Rick
I don't see any advantage to using synthetic 2-cycle oil in a CTD ..... other than the fact that most are smokeless. Are the non synthetics incorporating the smokeless technology yet? It's a fairly expensive additive system, so probably not.
RJ
Originally Posted by mxdsl183
im sorry guys, im totaly lost what kind of two stroke motor are you talkin about??!?!?
TCW-3 oil is more expensive to make because it is designed to burn cleanly at the lower cyl. head temps encountered in Liq. Cooled 2-stroke engines. It is the prefered 2-stroke oil for CTD's because of this fact.
RJ
Ok guys! I got 366 miles on 18 gallons, which works out to be about 20.3 per gallon. I usually see 17-18 combined mileage, with a best of 19. So this works out to be 2-3 mile per gallon increase!
So I'm pretty impressed at this point. In a few weeks I'm going to take a road trip and I'll let you all know the results of that.
Tye
So I'm pretty impressed at this point. In a few weeks I'm going to take a road trip and I'll let you all know the results of that. Tye
Tye
Tye
It looks like I will be trying this CRAZY oil additive concept to see if I can get some of those benefits too...
Big Jimmy
