'86 Ford L9000 w/ 400 big cam ?'s
I need some information.
We have the above dump truck here at work. When it's first started it is spraying oil all over the fan which really makes a mess. Once warmed up it quits spraying oil. It appears that the fan hub is lubricated by the engine oil. There are 2 oil lines (inlet and return?) that mount into a bracket which the fan pulley is attached to. There must be a bad seal there somewhere. Am I correct on this? I have no book to look at. Is there somewhere I can look at an engine brakedown on line.
Thanks.
Thanks.
I think the fan hub has a hydralic clutch for engagement and sounds like the seal is blasted. I think it runs on a thermostat in the oil system. Sorry can't help more with that.
J-eh
J-eh
SOhappy
Jan 3, 2011 09:40 AM
