WVO compatible FP sending unit
Anyone know where to get an electronic fuel pressure sending unit that is WVO compatible? I replaced my lift pump after seeing low pressures on the new gauges and it doesn't seem to have helped. I plan to try a mechanical gauge this weekend to make sure that it is the gauge and not another bad LP but I am thinking that the sending unit was not compatible. And just a note but I see the same pressures with WVO and #2 alike so it isn't the difference between the two.
I would think any sender would be compatible with WVO.
Actually diesel fuel is incompatible with more materials than most other fluids.
Here's chart relating to o-ring materials but many of the same materials are used for hose, sender diaphragms, etc.
http://www.efunda.com/designstandard...C=Diesel%20Oil
You might look though the chart, I'll bet it lists materials compatible with veggie oil, I know it lists the ones compatible with beer.
Personally if I found the sender to be shot I'd just replace the FP set up with a mechanical gauge.
Much more reliable.
Much more reliable.
Dieseldude4x4
Oct 24, 2005 09:12 AM
