Fuels / BioDiesel / Diesel Prices Use this forum to discuss your biodiesel information, and to find the best price on fuel.
Illegal diesel
Old May 29, 2006 | 10:18 AM
gerry's Avatar
I think that the early 07's will be ok with the fuel we have now..
I heard a rumor that Dodge 07's will still have the 5.9 in them until Jan 01 then it will switch to the 6.7 emission motor. Will it be an 07.5 or an 08 I have no idea.
Fords 2007 will still be the 6.0 up to january 1st then they will introduce the 08 model with their new engine. (just like they did in 03 with the early one had the 7.3 and later ones had the 6.0).
Don't know about Chevy.
Old May 30, 2006 | 12:27 PM
induchman's Avatar
I think you have that 2007 statement turned around. The way I see it this new fuel wasn't made for pre-2007 vehicles and so it may screw up the existing engines because the process to remove sulphur also removed the lubrication from the fuel itself. That means an additive needs to be put in to compensate. The 2007 engines should be just fine.
I'm not gonna worry about what kind of fuel I'm getting cuz my fuel supplier just gave me a 10 year warranty on my new farm equipment. Check it out fer yerself www.cenex.com/?Page=004467083&Path=0;0;1
Old May 30, 2006 | 12:30 PM
induchman's Avatar
Originally Posted by runamuk
If it is green it is legal for on road usage..................taxed as such.
If it is red you are looking at a 10k fine in Ca for using it in your on road vehicle!!!
Rick
If it's green, yellow green, yellow or clear it's taxed.
If it's black or red it's not taxed.
Old May 30, 2006 | 12:36 PM
kawi600's Avatar
For you folks that have pumps with LSD and ULSD side by side, how much of a difference in price are you seeing? There was speculation that once the stuff is fully adopted this fall that the prices would go up quite a bit.
Im assuming the intention IS to get rid of the LSD and switch completely over to ULSD..
Old May 30, 2006 | 01:01 PM
induchman's Avatar
About twenty cents higher, depending on your State fuel tax.
Old May 30, 2006 | 07:52 PM
infidel's Avatar
After Aug 1 LSD will only be available in red dyed offroad, onroad fuel will be all be ULSD. This only lasts a few years until all diesel will be required to be ULSD.
People are worrying way too much about the change, about the only difference you will notice is the higher price.
Old May 30, 2006 | 11:20 PM
BrewPub's Avatar
So does low sulphur and Ultra low sulphur mean the same in Europe?
I am considering in using a Euro Daimler-chrlyser v6 diesel in my Land Rover.
I have read that one of the problems with using Euro diesels here is the sulphur content in US Diesel fuel.
Anyone know if the Europeans are using Low sulphur or Ultra low sulphur.
http://www.vmmotori.it/en/01/00/01/index.jsp.
Old May 30, 2006 | 11:53 PM
Fueling around's Avatar
European standards are between low and ultra low. The engine performance doesn't change between the sulfur levels , the emissions ratings are compromised as wannadiesel posted.
The biggest difference between Euro diesel & NA diesel is cetane. Euro minimum is higher than NA maximum. NA is North America.
Old May 31, 2006 | 03:06 AM
H2SRDMB's Avatar
buy stock in power service. and buy it now whike its cheap.. im not chancing another 1500 vp-44
Old May 31, 2006 | 04:11 AM
BrewPub's Avatar
So can I use a modern high tech Euro diesel in America without engine mechanical problems and performance hit?
Old May 31, 2006 | 06:04 AM
displacedtexan's Avatar
There would probally ba ssome performance hit, due to the lower cetane.
Use an additive like the silver Power Service to help bump cetane up...
Old May 31, 2006 | 08:50 AM
6WHEELER's Avatar
Filled up yesterday at my normal fuel station and they had the hole LSD federal law in 07 diesel sticker on the pump, and also they stopped carring the 45 cetane and now only have 40. I'm guessing that the ULSD will have a lower cetane rating?
Old May 31, 2006 | 08:53 AM
RustyJC's Avatar
ULSD, according to Chevron, will have about 1% lower energy content (BTU/gallon) but higher cetane due to removal of more aromatics.
LSD = 500 PPM sulfur
ULSD = 15 PPM sulfur
Euro diesel = 50 PPM sulfur
Rusty
Old May 31, 2006 | 02:49 PM
schoonie's Avatar
what does all this mean for somone like me with a 12 valve. is there somthing i will have to do to my truck or what?
Old Jun 1, 2006 | 07:53 AM
Guardrail's Avatar
Originally Posted by tankeryanker
We are switching over to ULSD at the pipeline I load at on the 15th of July. That should give enough time to blend out the LSD before the new 07's hit the dealerships & are ready for sale.
This is a Kinder Morgan loading facility & the facility in Calif will be switching Sept 1st. That might be a problem for guys that take early delivery of 07 models.
The early '07 models (from June '06 to Dec 31, 2006) will have the '06 emissions. The EPA requirements are to take effect on vehicles produced on or after Jan. 01, 2007. The fuel companies were whining that there will be residual sulfur in the pipeline that would be picked up by any ULSD that was pumped through. That's why they are switching to the ULSD early.
