Fuels / BioDiesel / Diesel Prices Use this forum to discuss your biodiesel information, and to find the best price on fuel.
havn't used bio yet but
Old Jan 31, 2008 | 11:25 PM
GasganoFJ60's Avatar
Originally Posted by H8GAS
Oh, and you might clog a filter at B5. The lubrication and solvent affects are present at any amount of BIO used.
I ran b10 once and on the next tank my truck was feeling sluggish and fuel mileage dropped. I knew it might happen but I wasnt expecting B10 to be so potent.
Old Feb 1, 2008 | 12:52 AM
catnfool's Avatar
I started right off with b99- 33 gal. worth... I never clogged a filter, but changed one out in about 15k because I was scared. It was dirty looking, but was still running good. I'm scared to run it right now in MT tho. little chilly
Old Feb 2, 2008 | 09:24 PM
woodrat's Avatar
I was at the bio pump in the city today. here is the info on cold weather that was posted on the pump. I think these are very conservative suggestions, designed to keep anyone from ever having a problem.
if the low temp is supposed to be no lower than 45 F, then use 20% petro
if the low temp is supposed to be no lower than 32 F, then use 50% petro
if the low temp is supposed to be no lower than 20 F, then use 80% petro
I paid $3.69/gallon, petro today in the city was $3.35/gallon. If you save your receipts, you can get a $0.50/gallon rebate from the state of Oregon. Too bad I live on the other side of the river!
Old Feb 3, 2008 | 06:46 AM
Valv's Avatar
I've been reading this documents found on Biodiesel.org
http://www.nrel.gov/vehiclesandfuels...pdfs/40555.pdf
It is very interesting and bio is getting my attention now, I have a pump with B99 nearby and will go today to try a blend.
Old Feb 3, 2008 | 01:14 PM
jdunmyer's Avatar
I have an '01 and am thinking about running BD in it, as I have a source from a friend who's quite into it. My question is about compatibility of the BD with fuel system parts. I have the Vulcan filter relo kit installed, along with an Airtex pump from Autozone. Is that hose from the Vulcan kit compatible? What about other parts?
My plan is to only run it during warm weather, as I don't drive the truck much during cold weather anyway.
Old Feb 14, 2008 | 05:14 PM
woodrat's Avatar
for temperature concerns, I took a sample of the commercial bio I get in Portland from Sequential and popped it in the coldest part of the fridge. I looked at it today, and the thermometer next to it said 34 deg F, and there was no clouding at all.
Old Feb 21, 2008 | 09:21 PM
woodrat's Avatar
Another update on the B99 clouding. After a few days at 34 F with no cloudiness, I popped it in the freezer. After a couple of days in there, I checked on it and it was gelled totally solid at 22 F. It's been back at 34 for a day and it is starting to turn liquid again, but is still mostly solid.
Old Feb 21, 2008 | 09:31 PM
4thInf1969's Avatar
I'd run it but can't find a distributor in the South KC area. Anyone here know of any bio stations in my area?
Old Feb 22, 2008 | 12:08 PM
kawi600's Avatar
my b20 clogged up the filter in no time up here. A lot of the gel point has to do with the type of oil that was used to make the biodiesel. Soy is the most common and is notorious for being bad in the cold.
darkale69
Jun 27, 2008 10:24 PM
cLAYH
Jan 12, 2007 04:49 PM
98.5POS
Jan 6, 2007 06:36 PM
Intercooler
Jun 4, 2005 07:48 PM
