Fuels / BioDiesel / Diesel Prices Use this forum to discuss your biodiesel information, and to find the best price on fuel.
Fuel ? I know im gonna get bashed for this
Old May 7, 2008 | 04:37 PM
modifiedzx10r's Avatar
So one of my friends asks me a question about Jet fuel (yeah jet fuel). Supposedly he had some guy come into the cycle shop saying that you can use Jet fuel 101 with 2 stroke motor oil mix and with the correct ratio you can use this as diesel fuel. I have no knowledge on this so I present this to all you who are better minded then I. Truthfully I think this is BS. But I figure you could help me win my argument.
Nick
Old May 7, 2008 | 05:24 PM
RickG's Avatar
Here ya go http://www.madsci.org/posts/archives...4152.Ch.r.html
Old May 7, 2008 | 11:08 PM
gspbirdhunter's Avatar
100:1 is the ratio a coworker of mine uses who burns it in his Jetta. It took him one injection pump to figure that out though.
I recall reading that Jet A1 is listed as an approved fuel for the 6bt, maybe it was in the Dodge owners manual.
I don't burn slop fuel in my truck, instead I bring it home and pour it in the oil tank for the house furnace.
Old May 8, 2008 | 10:28 AM
DBLR's Avatar
Jet A can be used, I've read many post about it but they all said you need to mix in several qt's per tank of 30 weight ND oil. Only in the past month or so have I seen any one bring up 2 cycle oil to mix in with Jet A so I have no idea if it will work as good as the 30 wt ND the old timers have used for years.
Old May 8, 2008 | 11:31 AM
jrs_dodge_diesel's Avatar
Jet A (jet fuel), is a fuel that has a high flash point and low lubricity, and is nearly identical to kerosene. If you wish to run it in a diesel engine, do use some sort of oil (2 stroke oil would be ideal since it is designed to burn). Straight jet A would not be a good thing to run in any injection pump IMO. Except maybe the P7100 (12 valve pump), which is lubricated by the engine oil.
keith1992
Jan 7, 2009 08:43 PM
zack birge
28
Dec 22, 2008 08:02 AM
kthiemann
Jan 28, 2008 10:34 PM
DarrellB
Apr 29, 2003 09:25 AM
Cumminsdieselboy
57
Mar 10, 2003 12:28 AM
