Fuels / BioDiesel / Diesel Prices Use this forum to discuss your biodiesel information, and to find the best price on fuel.
Fuel Additive Question
Old Jan 26, 2007 | 01:44 PM
Cabinboy's Avatar
Bought 2001 Ram 2500 4X4 Quad in Summer. Should I put some time of fuel additive from time to time? Seems like when it dropped below freezing the truck seemed to hesitate (possibly fuel gelling).
Thanks in advance!
Old Jan 26, 2007 | 02:30 PM
rockingj's Avatar
you should be using a anti gel aditive in your fuel. I use it all year round to help keep the injectors clean & moisture out of the tank
Old Jan 26, 2007 | 02:57 PM
Howy's Avatar
I use Howes, and always add some at every fillup. Year round as well just for peace of mind.
Old Jan 26, 2007 | 05:48 PM
wrm's Avatar
wrm
tried power service grey and white boddle-stp -red line-amsoil-howes meaner power cleaner.by the best for power an mileage seems to be stanedyne preformance formula it is rard to find i get mine on ebay.
Old Jan 26, 2007 | 05:50 PM
Geico266's Avatar
Thanks in advance!
As the country converts to ultra low diesel you should be adding a good additive to every tank. Your injectors & IP will thank you.
Old Jan 26, 2007 | 06:03 PM
scottsjeeprolet's Avatar
You can get Power service @ Wally world white bottle. Get a fuel pressure guage, and check for codes, key on, off, on off on and the Odometer should show any codes.
Welcome to the DTR
Fill in your signature while your here.
Old Jan 26, 2007 | 11:35 PM
Devin_01's Avatar
well the only time i additive is in the start of winter when they are in the prosses of changing over to winter fuel.. Other than that i don't run any additive the rest of the year. I got 270,000 miles on my VP. Im not sure what kind of fuel you have down there but i know i got #1 fuel were i live. I have had zero problems.
Old Jan 27, 2007 | 07:39 AM
Shovelhead's Avatar
Administrator / Scooter Bum
Check out Stanadyne.com and look for your closest distributor.
I used to get mine mail order too until I found out there was a diesel injection shop 5 miles away that sold it cheaper than I was buying it (not even counting the shipping).
Old Jan 27, 2007 | 09:08 AM
wrm's Avatar
wrm
shovelhead can you give me the name of distributor i tried three in richmond all were more than i just paid on ebay 98 plus 20 shipping to va.i ordered a case of half gallons
Old Jan 27, 2007 | 09:11 AM
Shovelhead's Avatar
I buy mine at a shop in Springfield, Virginia that sells the 5 gallon pail of PF for $149.00.
The "convenient" bottle size is usually more expensive.
Where are you located?
Old Jan 27, 2007 | 09:15 AM
wrm's Avatar
wrm
thanks i will look them up on stanedyne web.
Old Jan 27, 2007 | 09:26 AM
wrm's Avatar
wrm
must not be a direct dealer only one in that area is in alexandria
Old Jan 27, 2007 | 10:13 AM
Shovelhead's Avatar
That's the one
Old Jan 27, 2007 | 12:15 PM
infidel's Avatar
If you're using #1 you need an additive more than ever. #1 is very dry with no lubrication properties that will eventually destroy your injection pump.
Old Jan 27, 2007 | 12:17 PM
pocketchange's Avatar
Acetone reduces soot (1 oz. per 5 Gals.) any more is a waste. Lucus fuel additive and LubeMaster fuel additive. Yes, all 3 at the same time. They all help out with the crud the powers that be have reduced fuel quality to.
Two Stroke oil of some type would be a positive.
Low sulfer fuel will be a headache for all of us, wait, you will see...!
