Fuels / BioDiesel / Diesel Prices Use this forum to discuss your biodiesel information, and to find the best price on fuel.
can I run peanut oil
Old Oct 3, 2006 | 04:24 PM
marv h.'s Avatar
I have some old peanut oil, I was wondering if anyone knows anything good or bad about useing it for fuel, or mixing in #2.
Old Oct 3, 2006 | 04:57 PM
XLR8R's Avatar
Sure - just be real careful about peanut allergies!
Old Oct 3, 2006 | 06:03 PM
wrglrroper's Avatar
Im with XLR8R run it but filter out the allergies.
Old Oct 3, 2006 | 07:39 PM
infidel's Avatar
How old is it?
Don't know about burning it in a blend with #2 but you should avoid rancid oils when making BD. Used oil should be turned into biodiesel as soon as possible, in order to keep it from going rancid and increasing the amount of free fatty acids. Rancid oil produces less biodiesel and may not even react to make it.
Old Oct 4, 2006 | 08:56 PM
marv h.'s Avatar
Thanks Bill, I didn't think of that. It is old. Some of it is probably 2 years old. I think I wil just dispose of it properly.
Old Oct 4, 2006 | 09:50 PM
foamdoc's Avatar
If you have enough to make it worth your while you can add some biocide (check autoparts store) to the oil to kill any bacteria. Be sure to do some filtering and you should be able to add up to 20% in your tank. If it gets below 60F cut it with some kerosene or diesel#1(10%-20%). The next alternative is make full blow biodiesel using methanol and lye, but that would be alot of work and research for just a little fuel additive. If your not sure, just pitch it. Next time buy some biostat and add to your used cooking oil when you are finished with it and it will prevent bacteria.
Old Oct 6, 2006 | 09:44 PM
marv h.'s Avatar
Thanks Foamdoc.
Muleman
36
Mar 3, 2012 01:12 PM
j-dubya
Dec 24, 2006 01:03 AM
guzzirider
Jul 7, 2006 12:22 PM
mikmaze
Jan 19, 2006 11:53 AM
tfarmer96
Aug 23, 2005 10:08 PM
