Enabling Cruise-Settable High Idle on NV5600
With the C&C factory mounted PTO option the hi idle is already enabled and works like a charm with the VGT, For a nice toasty cab in about 10 minutes
By installing the grounding pin yourself you have taken the liability monkey of their back.. Politely explain to them you understand the dangers involved with the system.. It is no more of a danger than the cruise control itself.. Besides hi-idle is needed for proper warm-up in colder temps as extended idling creates cylinder wash-down..
The ISB already has high idle feature that by default is activated in the ECU for cold weather warm up. CC won't activate under 30 mph so its completely different. The clutch switch is there so the driver cannot set the high idle, put the truck in gear, and either leave the vehicle or become incapacitated.
In a lower gear that does not exceed 5 mph the truck would drive thru a house, cars, and about anything else that was in its way and not kill the engine. Dealers have no idea who would do what and corporate is quite aware that it doesn't matter what happens they will be hel responsible for ANY issue that can traced to it. It sucks, but they have a point.
EB works as alternative warm up option also.
Yes I have and yes they did..
The same argument could be used against the cruise control. A truck traveling at 75 MPH would cause more damage than a truck at 5mph should the driver become incapacitated.. What's next a brain monitor attached to the ECM?? What about a cell-phone cut out switch too??
Read my sig line for the year, the pto option was a factory installed option, pto kits are available for people needing the "PTO" option to an existing C&C and otherwise truck.
[/QUOTE]
As I said, C&C's are a different animal as are the older systems. Light duty trucks do not come with a PTO option. You have an 05 C&C, not even the same creature as 03 2500.
Tell me this, can you engage PTO in a C&C and put it in gear with a factory install? If you can it has not been installed correctly.
Drive isn't going to step out of the truck for whatever reason at 75 mph and let it go. Not going to win that argument at any point.
OK. All of this is interesting and probably to the point re the liability thingy. So can anyone tell me a) I have the cold weather fast idle at below 0*C or 32*F so will grounding pin 22 enble the CCfast idle? or b) just install the Smarty Junior that is going to be installed anyway? I believe our local dealer here in not so litigious Canada will do the ECM update. Third question tha takes care of my American bros/sis's is - is there anyone out there other than a dealer that can do this with the correct OEM compatile software.
Yes! the fast idle is excellent medicine for the cold weather. Keeps the temps up too.
a) I have the cold weather fast idle at below 0*C or 32*F so will grounding pin 22 enble the CCfast idle? or b) just install the Smarty Junior that is going to be installed anyway? Third question tha takes care of my American bros/sis's is - is there anyone out there other than a dealer that can do this with the correct OEM compatile software.
b) That might work, might not depending on how the ECU is already configured.
c) Since it is proprietary feature in the ECU its doubtful if the others will allow manipulation of the those types of features.
I have yet to hear of somebody saying such and such tool will allow that manipulation. It might exist though, you will have to do some research.
-J
Just had the 05 enabled (after telling the dealer yes you can on a third gen 5.9
), the lack of a clutch cut/out switch was talked about but was not an issue..
Update:
The clutch cut/out switch is not needed.. When the truck detects it is moving (either direction) the truck returns to normal idle speed..
), the lack of a clutch cut/out switch was talked about but was not an issue..Update:
Badd Dogg Guy19
16
Nov 15, 2005 01:19 PM
rjm022
Oct 18, 2005 09:33 AM
