Electric Seats
Old Sep 3, 2011 | 02:07 PM
tejano's Avatar
Electric Seats
My seat back has layed all the way back and the switch won't move it back up. Is there any way to manually move it up without dis-assembling the whole thing? It's under warrenty but need to fix it this weekend.
Old Sep 3, 2011 | 08:25 PM
tejano's Avatar
I finally traced the problem to a bad switch. The one that adjusts the seatback is dead on one side. I ran a jumper to the up wire and raised my seatback up and removed the switch so it wouldn't recline again.
Old Sep 3, 2011 | 09:29 PM
Dr.Dizzle's Avatar
If you take it to the dealer for warranty work, I recommend you reinstall the switch. There are two motors under the seat base that have plastic gears, which have a high failure rate and tend to hum while depressing the switch. The dealers SOP is to replace the entire seat base (part#05080615AB) since the motors are considered non-serviceable parts of the base. I believe the approximate price for one seat base lists for 565.00.
Old Sep 11, 2011 | 12:25 PM
Asher's Avatar
This should make you feel better...
http://youtu.be/c731rOHAIoA
Old Sep 13, 2011 | 11:27 AM
samfox737's Avatar
Check out 2men1garage.com they have replacement seat motors for either up/down, forward/back. Motors run about $90 bucks
Old Sep 13, 2011 | 01:52 PM
Danavilla's Avatar
Good work tracing the problem and resolving the immediate issue (seat laid back). Since you say it's still under warranty, let the dealer worry about the permanent fix and its cost.
Diesel Girl
18
Oct 6, 2013 03:03 PM
92smokin blacky
Nov 6, 2010 10:17 PM
cj5er
Dec 20, 2009 09:19 PM
williamdr
13
Oct 20, 2007 09:39 PM
4RnrRick
Mar 16, 2007 07:46 PM
