Drive Shaft Repair?
Old Aug 16, 2009 | 07:59 PM
hotdram's Avatar
Drive Shaft Repair?
Drive shaft decided to separate from truck while towing 5th wheel to campsite.
U-joint between slip yoke and drive shaft exploded, tore the end of the drive shaft up a bit. Can't tell if I should use it as is (the ears where the bearings press in are chewed up a bit) or not. Going to take to a drive shaft place tomorrow. Never had to have one repaired. If they cut the end off and weld a new one on (and rebalance), will that be strong enough? Or should I start looking for a new or used (from junk yard) drive shaft?
Dodge wanted $98 just for the u-joint Would have to rob a bank to buy the drive shaft from them
Thanks,
~Rob
Old Aug 16, 2009 | 09:21 PM
dieselcamp's Avatar
If they replace the yoke it will be a good repair as long as they inspect the shaft and balace it. You should consider replacing the steady bearing I have replaced two on mine in 350,000 km.
Old Aug 17, 2009 | 07:57 AM
hotdram's Avatar
Thanks for the info dieselcamp
Pardon my ignorance, but what is the steady bearing?
Thanks,
~Rob
Old Aug 17, 2009 | 09:13 AM
RowJ's Avatar
Originally Posted by hotdram
....Pardon my ignorance, but what is the steady bearing?
Wondered same thing. All I can think of is the 'Center' or Carrier Bearing.... but your short bed doesn't have one.
Sorry for your mishap, Rob.
Not heard of that happening before! For a while, 2-3 yrs ago, seems like everyone was replacing U-Joints around 100,000 miles.
Haven't heard that so much lately. Your total Mileage?
I would not want weld/repair job, with your tow load ... just me! Maybe check with LazarSmith for advise?
RJ
Old Aug 17, 2009 | 01:41 PM
crobtex's Avatar
Dang Rob! Bet that was a little scary!
Old Aug 17, 2009 | 02:05 PM
XLR8R's Avatar
RJ
When it happened Thursday, Rob initiated a series of phone consultations... eventually culminating into his plan of action Friday afternoon.
Old Aug 17, 2009 | 02:12 PM
hotdram's Avatar
Little bit scary Charlie
Pulled the drive shaft out on the side of 377 north of Aubrey, put truck in 4 Hi and took camper to Ray Roberts SP
RJ,
117k on truck, not original u joints though. Napa u joints about 3 years old.
~Rob
Old Aug 17, 2009 | 03:45 PM
hotdram's Avatar
I brought the slip yoke and drive shaft to a repair shop this AM. Thought that if they could fix the drive shaft, they could then install a new u-joint in the slip yoke and drive shaft and I would be good to go. Turns out the slip yoke is dorked up too
After they determined the drive shaft was not warped, they told me they will weld a new yoke end on the drive shaft, balance drive shaft, install new greaseable u-joints at both ends of drive shaft and give me a slip yoke they have in stock (not sure if new or reman'd) for $252 out the door. Very happy with the price, hopefully they do good work and the slip yoke is acceptable. Find out tomorrow.
~Rob
Old Aug 17, 2009 | 04:35 PM
03RAMBUNCTIOUS's Avatar
I watch wind blow...
My buddy Scott (RedScooter , Red 05.) is laying under his truck as I type doing a U joint job, He is getting ready to stab it back in now, new ujoints front and rear and new tail housing seal after he trashed his earlier .
Old Aug 17, 2009 | 04:47 PM
bnold's Avatar
Yikes.. That doesn't sound like anything fun!! Surprised I haven't destroyed one of the 4 on my rear shaft by now... 160k miles and a good number of those pulling 30k plus loads out of pastures! Umm.. surprised Aggie Justin hasn't blown one either then!
Old Aug 18, 2009 | 05:39 AM
TexasCTD's Avatar
Do you think the Lazarsmith Traction bars might be playing in a role in their longevity? Course that doesn't explain Justin's good fortune, yet.
Old Aug 18, 2009 | 06:34 AM
bnold's Avatar
I'm sure they help... Without and when I was running 315s, I had made the tires rub the front of the rear fenders a couple time in the past... Hate to know what my pinion angle looked like then!
Old Aug 18, 2009 | 12:40 PM
TexasCTD's Avatar
Perhaps something like this...??
and now...perhaps this?
Old Aug 18, 2009 | 01:55 PM
WOW to the videos.
I need bars.
Old Aug 19, 2009 | 07:36 AM
XLR8R's Avatar
Impressive video!
Made a believer out of me!
