Secure Footing for Any Job with CARR I Grip Strut Side Work Truck Step at CARiD
Service trucks are designed to handle a wide range of tasks, offering ultimate versatility and optimizing the workflow. If you’ve been struggling to keep up and looking for a way to work more effectively, our Grip Strut Side Work Truck Step by CARR is the perfect solution.
Engineered for hands-free operation and durability in the toughest job sites, it provides quick and easy access to your tools, helping you complete tasks more efficiently. Whether you're reaching top racks, exterior toolboxes, or equipment, this rugged step makes climbing in and out of your truck safer and easier than ever. Crafted in the USA from durable aluminum with interior steel straps for added strength, it can handle even the heaviest workloads and support up to 500 lbs without bending. The Grip Strut Side Work Truck Step features a wide, non-skid surface, providing secure footing for both feet. It is made to last many seasons and is highly resistant to corrosion.
CARRŽ - Grip Strut Side Work Truck Step
Specifications:
No matter the industry, service trucks often come equipped with specialty equipment. The Grip Strut Side Work Truck Step by CARR is compatible with industrial, commercial, utility, service, and fire prevention trucks, ensuring quick and effortless access to the truck bed when you need it most. CARR steps arrive fully assembled and ready to install. Using it is as simple as 1-2-3! Just push the step in to deploy it, and push it again to lock it away when not in use.
Specifications:
- Weight Capacity: 500 lb
- Color: Two-Tone
- Material: Aluminum Construction with Interior Steel Straps
From secure footing to easy accessibility, the CARR Grip Strut Side Work Truck Step is the perfect addition to any hardworking truck.
Explore our range of steps, grab handles, locking tie-down straps, and other versatile accessories for your workhorse at CARiD: https://www.carid.com/carr/
Stay well-equipped, get your job done efficiently, and improve your service delivery with CARR.
Buckshotmckee
Mar 29, 2008 05:04 PM
