Cummins Inline 7
Cummins Inline 7
Hello all. I have a new Cummins INLINE 7 that I purchased and a 2017 NED. I loaded everything up and connected to the truck. It did not auto-detect the engine, I had to select it from the list. It looks like its showing the "Signal values" with actual voltages and such, but none of the other screens display anything. No DTC codes, nothing.
I also noticed the NED user guide does NOT list the Inline 7 as a compatible link. It does list the Nexiq though.
Can anyone confirm that the Inline 7 does indeed work with International + Maxxforce engine, or do I need to try a Nexiq?
Thanks..
Thanks..
Anyone out there have Cummins Insite Software/Hardware Kit and if so is it ... Insite Engine Diagnostic Software Lite with Cummins Inline 7.
The Cummins INLINE 7 data link adapter communicates with your PC using a Universal Serial Bus (USB) through a standard USB connector as well as through WiFi or Bluetooth.
What is difference of Cummins Inline 6 VS Cummins Inline 7
Cummins INLINE 7 DataLink Adapter has a faster processor, more robust algorithms, larger memory buffers and more sophisticated filtering than previous models while simultaneously accessing multiple vehicle data channels. And we also have Cummins inline 6,what is the difference?here we have comparison between them.
Software:
Cummins INLINE 6
1. Comes with Insite 7.6 software (2013)
2. Pay to use Insite 8.2 8.3
3. Only works with Win7
4. When install insite, you need to change the computer time which is not easy to do.
CUMMINS INLINE 7
1. Comes with Insite 8.3 software (2013)
2. The software is authorized for free, what the user to do is enter the serial number.
3. Works with WIN7 WIN10.
4. No need change the computer time, easy to install.
Hardware:
CUMMINS INLINE 6
1. Inline 6 warranty: 1 year
2. The iron shell is heavier and not easy to take.
3. For a long-time use, the two rows of hollow pins are easily poor to contact, broke or bent.
CUMMINS INLINE 7
1. Inline 7 warranty: 3 years.
2. Comes with double-layer plastic which is anti-stress and stable, it can protect the circuit board well.
3. The outer layer is soft and comfortable to the touch..
4. The three rows of solid pins are durable,its warranty is 3 years.
s5. The circuit board design is more tidy, the PCB line impedance is adjusted and optimized, the product life is improved, and the stability of the equipment is ensured. The maximum warranty is three years.
Software:
Cummins INLINE 6
CUMMINS INLINE 7
Hardware:
CUMMINS INLINE 6
CUMMINS INLINE 7
Cummins INSITE 8.7 Software 8.7 Pro Version No Time Limited
Software Version: Cummins INSITE 8.7 pro
Operating System: Win10 System
Support Multi-Language: English(united states)/ Chinese(simplified)/ Danish/ Dutch/ Finnish/ French/ German/ Italian/ Japanese/ Korean/ Norwegian/ Portuguese/ Russian/ Spanish/ Swedish/ Turkish
CUMMINS INSITE 8.7
Size: 13.1MB (Winrar Files)
Language: English
Instruction: Present
OS: Window 7, Window 8, Window 10 32 & 64bit (Tested on window 10 pro-1607 64bit)
High-Speed Link Download
CUMMINS INSITE 8.7
Language: English
Function: Cummins Insite 8.7.0 version.
Cummins INSITE 8.7 Pro Feature:
1. Cummins INSITE 8.7 Pro No Time Limited, can use it all the time
2. Cummins INSITE 8.7 Pro work with Cummins inline 7/6/5 hardware for all Cummins engine trucks diagnostic & programming
3. Cummins INSITE 8.7 Pro cover all function of Cummins INSITE 8.5 Pro version
4. Cummins INSITE 8.7 Pro including Automotive Calibrations Data Cummins INCAL and Reflash ECU data, read & write ECU
Hello , this cummins inline 7 support both wifi and bluetooth ,thank you
__________________
I love life, optimistic, positive! Love the unique approach to solving puzzles. www.cnautotool.com
__________________
...Ben
Hi all
I am going to by by adapter for cummins but I am confused between inline 7 and nexiq usb link 2.....
What is different between Cummins Inline 7 and Nexiq USB Link 2?
Here share some users’ experience as following:
1:Cummins INLINE 7 Data Link Adapter Cummins Truck Diagnostic Tool with Cummins Insite 8.5/8.7 Software
Cummins INLINE 7 Data Link Adapter has a faster processor, more robust algorithms, larger memory buffers and more sophisticated filtering than previous models while simultaneously accessing multiple vehicle data channels. INLINE 7 supports USB, WiFi and Bluetooth technologies in a single device.
2: NEXIQ 2 USB Link + Software Diesel Truck Diagnostic Tool With All Adapters
NEXIQ 2 Support Heavy-Duty, Light-and Medium-Duty Trucks, CONSTRUCTION EQUIPMENT like (Wheel loader, Articulated Hauler and Excavator), Genset.
Cummins 7 is built by Nexiq for Cummins. and the Cummins have both Bluetooth and wifi and slightly faster even when looks same. the Nexiq 2 just have the Bluetooth you can choose.
Nexiq 2 have more protocols than Cummins 7,for example the Cummins 7 doesn’t work with Hini ,Toyota, Isuzu.
Cummins INLINE 7 Adapter for everything from ddct to Jpro and N14,from old to new works great for programming real fast,sometimes Cummins only like Cummins adapters, like N14 m11 570 .
Hope it help!
Hope it help!
...Ben
