conversion cummins to ford with a dodge cab
Old Nov 6, 2008 | 04:24 AM
  #31
Erska's Avatar
Can't you just use the stock Dodge frame and convert it to Cummins and put a 4x4 front on it?
Old Nov 6, 2008 | 08:50 PM
  #32
Alwaysworking's Avatar
alwaysonDTR
no i do not have the crew frame anymore and since the ford is allready 4x4 (and i to lazy to convert 4x4) i will strech the frame on the ford.
i would strech the 1st gen dodge frame but mine is a short frame 6 inch and the ford frame is 9 inch which i have frame peices to strech it with. the fords also ride better than the 1st gens,
i am now also thinking, i might try a 9 foot box
Old Nov 10, 2008 | 07:37 PM
  #33
alwaysonDTR
found some dually dodge fenders off a 90 so now i can run a pick up box,
the peices are comeing togeather, now i just need to find a ford 205t-case or do the front end houseing swapt
Old Nov 11, 2008 | 08:54 PM
  #34
alwaysonDTR
found a ford 205, i just have to make an adapter to the getrag,
also found a frame, just have to see if its good.
Old Nov 21, 2008 | 12:04 AM
  #35
alwaysonDTR
heres the frame
t-case
Old Nov 26, 2008 | 07:45 PM
  #36
alwaysonDTR
picked up the rear end today, 4:10's with no locker but i have a locker to use in it, and i going to 3:54's so to not need another over drive
Old Dec 5, 2008 | 01:05 AM
  #37
alwaysonDTR
rear end is under it, but i need some 4inch blocks and u-bolts
also ready to put in the front end
Old Dec 7, 2008 | 12:26 AM
  #38
alwaysonDTR
rolling chassis now
Old Dec 8, 2008 | 12:21 AM
  #39
alwaysonDTR
http://i289.photobucket.com/albums/l...s/DSCF5190.jpg
Old Dec 13, 2008 | 12:14 AM
  #40
alwaysonDTR
rear cab mounts are made, front ones need to be welded, then on to the box i guess
Old Dec 18, 2008 | 01:32 AM
  #41
Kansascrewcab76's Avatar
Very cool!
Old Nov 13, 2009 | 02:52 PM
  #42
alwaysonDTR
haven't done much to it, other than i know which truck i'm using for a donor now, my white truck will be the one since i want a crew cab with some power and if i use the blue truck as the donor i would have to buy to many parts abd then would still drive the white truck because i like it.
and the blue truck is in better shape than the white one.
Old Nov 13, 2009 | 03:34 PM
  #43
rockcrawler304's Avatar
Any new pictures from the last year?
Old Nov 25, 2009 | 01:39 PM
  #44
alwaysonDTR
maybe somewhere but it is still about the same except the box is full of parts
Old Apr 29, 2010 | 12:29 AM
  #45
alwaysonDTR
engine mounts are done, had to cut the firewall to set the engine back far enough, hood is painted, trans mount is next. then t-case adapter.
