73 Crew Cab 2nd Gen
Old 09-13-2016, 03:02 PM
  #31
73CrewCab's Avatar
Ahhhh much better. A P-pumped 73 crew cab! If dodge would have only offered one from the factory...Name:  image_31.jpeg
Old 09-13-2016, 03:04 PM
  #32
73CrewCab's Avatar
I'm still waiting for cab mounts and a stupid body lift to arrive in the mail. I hate body lifts, but I need the extra room for the fuel tank, transmission to tunnel clearance and it should make stuffing the 2nd gen radiator, IC and A/C condenser behind the early front grill a little easier.
Old 09-13-2016, 04:46 PM
  #33
BHD
BHD's Avatar
Nice work. Ill be watching.
Old 09-13-2016, 05:34 PM
  #34
Received 2,392 Likes on 1,576 Posts
Ditto.
Nice work man!
I will be watching this closely as well.
Old 09-13-2016, 10:34 PM
  #35
73CrewCab's Avatar
Thanks guys! So far, I'm into this conversion 7 days. Hopefully next week, I'll have the fuel tank in and have her running. Still have to figure out the rear drive shaft...1 piece vs 2 piece. It's going to be roughly about 72" long
Old 09-14-2016, 12:41 PM
  #36
73CrewCab's Avatar
Ive ordered a lot of parts for this project (door seals, weather stripping, tail lights, wiring etc.) from LMC truck. Somebody there took the time to hand write a thank you card. It wasn't some generic pre-printed, everybody gets one type of deal, so it actually meant a little something to me. I will be ordering from them again in the future for most of my needs, just because they've been so good to deal with.
Old 09-18-2016, 04:35 PM
  #37
73CrewCab's Avatar
Today I'm drilling out the rivets on the 2nd Gen fuel tank cross members. I'm hoping that I can reuse them on my frame as well as the 2nd Gen fuel tank.
Old 09-22-2016, 06:10 PM
  #38
73CrewCab's Avatar
My brother in-law dropped off some goodies for me this morning...I got an 89 core support to replace my severely rusted 73
Old 09-22-2016, 06:12 PM
  #39
73CrewCab's Avatar
And a stack kit. Eventually I'll run a single 7 or 8" stack, but this setup was free, so I'm going to run it for now. Name:  image_36.jpeg
Old 09-22-2016, 06:13 PM
  #40
73CrewCab's Avatar
Mocked up just to see how it's going to look.
Old 09-22-2016, 06:24 PM
  #41
73CrewCab's Avatar
My biggest problem I'm having is the fuel tank. The 2nd gen single cab long bed is way too tall, even with the 3" body lift. I'm not really sure how to tackle this.
Option 1. Use a 1st gen tank. Can I use this with a P-pump motor? Would I use the 1st or 2nd gen sending unit? If I used the 1st gen unit, would the fuel lines directly hook up to it?
Option 2. Try a 2nd gen short bed tank. Not sure if the size/capacity would be any different between a QCSB or single cab long bed.
Option 3. Use my original In-Cab tank (behind the back seat) and try to do some magic for fuel line hook ups.
Option 4. Use a Ramcharger tank. And change out even more cross members. same questions as option #1
I can't get a used tank from the junkyard, because here in Southern California, they punch big holes in them to drain them out. I have to rely on Craig and Evilbay.
Old 09-22-2016, 06:30 PM
  #42
73CrewCab's Avatar
Is there an Option #5 for tank choices? I'd like to have a minimum of 30 gallons and I don't want to lose anymore bed space. I've already got the stacks and a 48" Ridgid toolbox in a short bed.
Old 09-23-2016, 07:08 PM
  #43
73CrewCab's Avatar
Since I don't have a tank that fits yet, I've decided to see what I can do with the core support. It looks like I might be able to combine the 95 and early core supports to make 1 that works.
Old 09-26-2016, 09:07 PM
  #44
73CrewCab's Avatar
Well, I got the old Dana 60 rear axle out. Loaded up all of my scrap steel onto the trailer, cleaned up the shop (aka my patio), and pressure washed everything so it doesn't look like a junkyard, and we can have people over again. My wife is a lot happier now.
Old 09-26-2016, 09:14 PM
  #45
73CrewCab's Avatar
Tomorrow's to-do list is to install the 2nd Gen Dana 70 and install the fuel tank cross members. I ended up using a heat gun to flatten out the front most bulge in the 2nd Gen SCLB tank. It works for now, but I'll be looking for a 34 gallon Cummins short bed tank (98+) in the future.
Quick Reply: 73 Crew Cab 2nd Gen
