3.9L into a '99 dakota
Old Feb 14, 2008 | 07:04 PM
Dodgehunter84's Avatar
I just bought a 3.9 liter cummins out of a Case 588G fork truck. I am wanting to put this into a '99 Dodge Dakota, any suggestions on transmission, and gearing to use would be helpful. This engine doen't have a turbo and i want to put one on it. Any sugggestions on turbos would also be helpful.
Old Feb 15, 2008 | 01:56 AM
Tate's Avatar
I'd say check out 4btswaps.com. Lots of guys over there, a couple that have swapped them in Durangos. I know one guy wound up using an NV4500 in it, not sure what he did for t-case though.
Old Feb 15, 2008 | 06:39 AM
xtoyz17's Avatar
Probably looking at modifying or replacing the injection pump on that. They had different types and tunes for injection pumps based on application and turbo/non-turbo.
4btswaps.com is a great place to start, or the 4BT user group on yahoo.
Shawn
Old Feb 15, 2008 | 01:26 PM
JD730's Avatar
Shawn
I would use definitely instead of probably. Those CAV pumps don't throw alot of fuel even when turned up.
I've been helping a friend of mine out with the same kind of setup, non-turbo to turbo. Had the pump turned all the way up and wasn't enough fuel. He picked up a VE and I went through it for him, 3200 rpm gov spring, plus other tweaks. Night and day difference.
CAV to VE pump swaps are easy, the pump gear has to be rotated to a different letter on the gear. As long as you get all the plumbing its a piece of cake.
Old Jul 16, 2008 | 08:44 PM
Half way point.
I have the engine in the truck and I am waiting for the inline pump to come back from Scheid diesel. Once I get it on I can test fire it. I put a NV4500 and a t-case that I salvaged from a wrecked '97 2500 ram.
Old Jul 16, 2008 | 09:01 PM
j-fox's Avatar
I am putting a 4BT in a 99 Durango 2wd.
I got started on it and was hit hard in my truck, been delayed but may be getting back to it soon.
what did you do with motor mounts?
I am going to use the 47re, hoping I can get everything working like tach etc.
Old Jul 18, 2008 | 02:30 PM
95Z28A4's Avatar
Durango Builds
The links below are to 4BT Dodge Durango builds. Yours being a 1999, should be a little easier without the rack & pinion steering.
http://www.4btswaps.com/forum/showthread.php?t=1910
http://www.4btswaps.com/forum/showthread.php?t=881
Old Jul 20, 2008 | 08:52 PM
smcminn's Avatar
I am a new guy. The conversion I want to do is to put a 4 bt into my 1994 Dodge 1500. I am a jr. geezer or greybeard and want to maintain the auto tranny. The truck has a 360 gas engine. I appreciate the threads and will look at both 4btswaps and the yahoo site. I understand motor mounts need to be made and the 46rh may need to be beefed up to hande the conversion. Would anyone know if this sounds right? Another thing I will need to find a service shop that does good work. Is anyone familiar with Antrim Diesel in Greencastle, Pa? I would like someone in Va as that is where we live. Any feedback is appreciated. Thanks
Old Jul 20, 2008 | 09:36 PM
Raspy's Avatar
I'll be interested to see how you work out the front differential "problem". On those trucks with the independent front suspension the differential mounts on the engine!
As far as gearing goes, mine was geared way too high for the gas V6 that was in it so maybe the gearing won't be too far off for the Cummins. Get it going and see what you think. There are also heavier duty rear ends available for them, so if you change the gearing you might just change the whole diff instead and get a tougher setup to run behind the diesel.
Old Jul 21, 2008 | 07:44 AM
j-fox's Avatar
I looked until I found a 4X2 durango, bought it on E-bay. It needs top ball joints and a little TLC but good other wise.
Old Aug 4, 2008 | 09:53 PM
new front axle
I am putting a Dana 44 from a jeep under the front and doing away with the IFS.
Old Nov 19, 2008 | 10:26 PM
My dakota is in its testing stages now, I drove it around in the field yesterday with only the drivers seat in it and just the down pipe. It has some power.
Old Nov 20, 2008 | 09:25 AM
j-fox's Avatar
Any photos of the oil pan area?
Old Nov 20, 2008 | 09:57 AM
tech1's Avatar
new to the site also, been doing alot of reading A buddy and i just got done putting a 4bt in a M Farmell fit perfect!!! runs great.
Old Nov 20, 2008 | 09:31 PM
I put a HX25 holset on it which I found out was a stock turbo for the 3.9 engines that are factory turbocharged. I will probaly go bigger.
Last edited by Dodgehunter84; Nov 21, 2008 at 10:18 PM. Reason: left out something
