2003 Ram 2500 Hemi to 12 Valve Cummins?
Old Oct 11, 2013 | 09:48 PM
2012mciga's Avatar
I recently picked up an 03 Ram with a blown up Hemi in it and was thinking of swapping my 12 Valve out of my rusty old 94. Was wondering if anyone who had done the swap could give me a few pointers on what I would need motor mount wise and what I would need from a Common Rail or use from the Hemi?
Old Nov 3, 2013 | 03:45 AM
Gen414's Avatar
Motor position will be different. Is the '03 2WD or 4WD? You will have to re do the motor mounts, but that's the biggest difference/hardest part. Obviously you will need a trans, because the trans that bolts up to the Hemi, will not work behind the Cummins. Also change out fuel pump/lift pump. On the Hemi, pump will be in tank. That pump puts out @ 50+ PSI, and the lift pump in the 12 valve (and all Cummins for that matter), are low pressure pumps. Not to mention, you would need to change out fuel lines anyways...from fuel tank to lift pump.
But getting the actual 12 valve up and running, would be the easy part.
Radiator/fan/fan shroud will all be different as well. Not sure why you mentioned Common Rail. From what I read, you have a '03 Gas motor 2500, and wanting to drop in a 12 valve motor in it. So...where does Common Rail fit in?
Old Nov 3, 2013 | 10:15 AM
2012mciga's Avatar
It is 4WD. I decided I'm going to look for an NV4500 to hopefully save a little bit of trouble. And the Common Rail fits in because I read on a few other threads here and there they used some parts off a CR to get some things working. And I was thinking for the radiator, fan, IC, and all that using CR parts would for the most part be basically usable. Might just need some piping.
cruizer32
20
Dec 16, 2013 08:16 AM
buzzinhalfdoz
30
Mar 11, 2009 07:58 AM
Olli
0
Apr 1, 2007 12:34 PM
Journier
Dec 16, 2005 02:42 PM
