1991 Dodge Ram 3500 diesel Cummins dually tail light issues
Old Feb 12, 2019 | 04:45 PM
Travis Bradley's Avatar
No tail lights or running lights. Changed multi function switch, checked all fuses and bulbs. Have brake lights and blinkers and hazards work. Any ideas???? Need help
Old Feb 12, 2019 | 08:10 PM
there are two disconnects , one on each side of the truck, up under the bed in the frame , behind each rear wheel. These disconnects get all funky inside. Find them, and use a test light to see if power is on the front harness, and not traveling across the connector
Old Feb 12, 2019 | 09:38 PM
Thank you, I will try it tomorrow
Old Feb 13, 2019 | 01:06 PM
I had the same problem you've described. I wound up having to bypass the connector with a separate wire because the connector had eroded over time.
Good luck.
tack514
Apr 18, 2019 08:46 PM
rmillett
3rd Gen All Products
May 24, 2016 03:16 PM
Pinkston
2nd Gen All Products
Feb 27, 2015 07:39 PM
JStevens85
14
Aug 12, 2014 01:38 PM
ClawHammer
Jan 7, 2004 01:31 AM
