1966BT Dodge Camper Special Resto/Mod
Old Nov 9, 2011 | 11:30 PM
Hey Great project you have there...and I agree that you made a great choice going with a cummins/5speed set-up instead of the BB. I have always loved those early D/W Dodge trucks....I'll be watching with interest.
As for the power steering pump on the motor. If it's a Non-IC motor then they run a different Vacuum/power steeing set-up then the IC trucks. If you get an IC vacuum/power steering set-up it should work...since they used the same set-up from 91 to about 2000? on all the cummins trucks.
Old Nov 10, 2011 | 12:41 AM
lowdown's Avatar
Nothing on the truck will require vaccum so can I remove the vaccum portion off the new pump?
Old Nov 12, 2011 | 09:51 AM
bearvally's Avatar
Nice looking project! You most certainly can remove the vacuum portion of the pump, I stripped both diaphragms and fabed up some aluminum plates to block the ports and ran it. As you are aware the mount set-up prevents removing it entirely as the ps is driven off the back of the vac, but you can definitely streamline the system.
Old Nov 13, 2011 | 09:47 PM
You can definitely do as Bearvally says....as long as it's the Non-IC style with the pods. But if you keep your eyes open on E-bay you can get a straight power steering set-up from a 4bt cummins motor, and some industrial 6bt set-ups. No vacuum pump portion, just straight PS.
Old Nov 16, 2011 | 03:52 PM
wheelieking71's Avatar
nice project! you have my attention!
Old Nov 17, 2011 | 08:30 PM
lowdown's Avatar
I found an engine plate and a clutch fork but I'm still looking for a bell housing.
Heading to the classifiedes now..
Old Dec 18, 2011 | 09:31 AM
Mopar1darrell's Avatar
As an avid off roaded(last truck 93 dakota w 60's) and 4 door owner and ctd 92, i love this project. Look forward to seeing more
Old Dec 18, 2011 | 09:40 PM
lowdown's Avatar
I appreciate the kind words and have some updates:
About three weeks ago I decided to link and bag the rear of truck. I've got high expectations for this truck and think the additional cost will be worth it. I admit it, I'm not breaking any new ground and linking/bagging a truck has been done plenty of times. As a matter of fact, take the time to read this thread in which the fabricator 4 linked and bagged a brand new F450 because the owner was really disappointing with how it carried a load. The truck is now 4 linked (w/ a track bar), bagged, has a simple air system and the owner is still happy with it about 4 years later and several 6K lbs payloads later.
http://pirate4x4.com/forum/showthrea...highlight=f450
The tentative plan is to use a pair of Goodyear air bags (http://www.sdtrucksprings.com/index....ducts_id=16373), a stand alone compressor, along with the same joints that I'm using on the front end. Will it cost more and be a hell of alot more work, absolutely. But I think it'll be great in the end and exceed my expectations.
Old Dec 18, 2011 | 09:41 PM
lowdown's Avatar
My polybushings.com Cummins motor mounts arrived a few days ago, the air bags yesterday, front and rear trusses, link brackets, and more bushings, are on the way. I've emailed the .DXF files to about 4 places and am supposed to have some quotes today. My buddy Barrett, the CAD guru has done in a few more drawings for me including some adjustable bracket plates. I spoke to Dave and Allen Ballistic Fab about stepping it up on the motor mounts but I'm not holding my breath..
Motor mounts:
http://polybushings.com/pages/2710.html
Air bags:
Laminate plate drawing:
Old Dec 18, 2011 | 09:42 PM
lowdown's Avatar
I've been making some progress behind the scenes but have not touched the truck for a few weeks.
I sent my CAD drawings to several local Baltimore companies who have CNC cutting capabilites. They either came back at over double my budget or never got back to me.
I then sent the drawings to Kert @ DIY4x.com who came in under budget and has been great to work with since. He's going to start cutting the plates on Monday and is making a set of mounts for the air bags too.
The bag mounts will be similar to these but super sized to fit the 11" diameter air bag.
The trusses arrived a couple of days ago and are awesome. My inner over killer is is very happy.
Also, Allen @ Ballistic sent me a finalized version of the motor mounts for the Cummins conversion.
Once I get the plates from Kert, and if the weather is decent, I might start welding 'em on the frame.
Old Dec 22, 2011 | 09:32 PM
lowdown's Avatar
Kert @ DIY4x.com came through like a champ. He cut me an unbelieveable price for the air bag to axle mounts, air bag top plates, inner and outer frame plates, some tabs, and shipping. Here's just a sample of his work:
to
to
I'm looking forward to working with Kert again.
Old Dec 23, 2011 | 08:00 PM
lowdown's Avatar
More of Kert's work:
Concept
Drawing
Final product
Old Dec 24, 2011 | 09:38 PM
lowdown's Avatar
Since we were on the subject earlier:
A comparison of the vaccuum pumps from an early first gen versuses a later first gen:
1990 (non-IC):
1992 (IC'd):
Old Mar 4, 2012 | 02:25 PM
Herrell4's Avatar
Subscribed to this thread. Interested to see how it will turn out. Great work BTW. Awesome project!
Old Mar 5, 2012 | 06:29 PM
6cylinders's Avatar
Very cool! Keep up the good work.
I really enjoy watching big projects like this.
You will really have something when it is done.
