Coolant Froze Solid in Radiator (block unknown)
Old Jan 7, 2010 | 08:00 PM
streetsmoker's Avatar
Just as the title says the radiator is froze solid but don't know about the block yet.....forgot to plug in the block heater and its gotten very cold and thought I had enough antifreeze to keep safe down to zero.....what's my chances everything is ok once things get thawed......any advice would also be greatful
Old Jan 7, 2010 | 08:08 PM
olddodgetrucks's Avatar
if there was any avnti freeze it is prob just jelled,start the truck,put cardboard in front of rad,let it run till block heats up,stop let it sit for a 1/2 hr and do that a few times and it will thaw,anti freeze is CHEAP
Old Jan 7, 2010 | 08:25 PM
No, unfortunately it is frozen ice and slush.....so now what? There was some antifreeze in it, but most was drained for the race track rules a few months ago and now it just dawned on me why it froze
Old Jan 7, 2010 | 09:00 PM
67HotRod's Avatar
If possible drag it inside where it can thaw and look for leaks.
Old Jan 7, 2010 | 09:27 PM
jkitterman's Avatar
Plug it it now. If you have a heater, tarp the engine compartment and get it warming up. You need to drain some of your water mix and add straight coolant until you can get it to the proper mixture. See if you can get some test strips to see how far off you are. If the block freezes, it may crack. You are also risking the heater core and radiator.
Old Jan 7, 2010 | 09:53 PM
catnfool's Avatar
I got lucky with a mustang in the same boat; like he said- plug it in right away and when the block heats up, it will be apparent if you have troubles... I also second the starting it, letting it pump into the rad., waiting, and repeating. Good luck- spooky stuff here!
Old Jan 8, 2010 | 12:38 AM
Unable to pull it inside of the garage, obviously......cause cranking it could ruin the water pump and whatever else. Plugged in the block heater, tarped the entire front of the truck back to the doors, got one space heater and a heat lamp warming the engine bay. We'll see in the morning how things are.......hoping upon hope and praying things are ok, and like you say.........scarey stuff indeed!!!!!
Old Jan 8, 2010 | 07:42 AM
patdaly's Avatar
If it was just slush, you are likely OK.
Old Jan 8, 2010 | 02:10 PM
Yeh, the radiator was slush, but both the upper and lower hoses were froze solid.....block temp is now at 55* and there is little to no ice in the radiator. No leaks to report, thank God!!!!!! Just wondering now if its safe to try and crank it up or let it sit awhile longer
Old Jan 8, 2010 | 03:10 PM
read my post i,v done this may times,for other people
Old Jan 8, 2010 | 07:10 PM
Yeh, and thanks for all the good advice!!!!! Went to try and crank it and now with the cold weather it seems I have a couple bad batteries. Had them trickle charging for a couple days and voltage test out at 13.1v and 100% charge but will barely turn the engine over and lights dim down severely with the grid heater cycle.
Old Jan 10, 2010 | 08:32 AM
tyler5.9's Avatar
baterys are most likly bad do a load test on them or take them in and have them load tested they will charge but will not take any load
Old Jan 14, 2010 | 12:16 PM
mj007's Avatar
Only thing about that is if the radiator is froze enough that the coolant isn't moving at all, then the engine will get too hot and spin a bearing or take out a rod way before you get any circulation in the block ..... been there and done that!
jlipskoc
Aug 27, 2007 06:34 PM
TurboShadow
Jun 5, 2006 12:08 PM
04ctd
Dec 31, 2005 05:14 PM
Geico266
Mar 7, 2005 01:13 PM
tanderson2002us
Jan 12, 2004 10:16 PM
