What is that white puff of smoke?
Old May 23, 2006 | 11:18 PM
Crimedog's Avatar
Sometimes at the pulls I go to there will be a hopped up tractor or a diesel truck that is building boost and once they begin to launch POOF The smoke changes to white and just fogs out. What is this? I saw one Cummins that did this and he came back for the next class... so that seems to rule out my suspiscion of blown turbo... any ideas?
Old May 24, 2006 | 12:26 AM
Ph4tty's Avatar
I think it was a 12ver with the timing set high.
I like to watch the smoke change colors
Old May 24, 2006 | 12:42 AM
oestreich84's Avatar
I thought white smoke was raw fuel, and black smoke was partially burned fuel
Old May 24, 2006 | 06:07 AM
PourinDiesel's Avatar
Fuel or a combination of fuel and water.
High timing will get the white smoke at idle or even just increased fuel delivery. Or a decompressed engine etc.
Old May 25, 2006 | 09:21 PM
Crimedog's Avatar
Sorry I didn't specify too well... I should point out that this ended their runs, definitely not supposed to happen so something went wrong. I've seen some that have the heavy gray smoke while it's loping away waiting for more RPM, but what I'm talking about is a failure of some sort. Pourin, I see you said decompressed engine... so would that mean an intercooler boot or blown turbo?
Old May 26, 2006 | 01:48 AM
Well that is a possibly...or even a blown turbo.
But what I meant was that they have fly cut or shaved the pistons to lower the final compression ratio of the engine to allow for more fuel delivery or boost etc.
Old May 27, 2006 | 01:29 PM
trailrydr9's Avatar
They didn't get the turbo to "Light" They were running a huge amount to Water, and didn't get enough fuel / RPM to make everything launch like it should. 2 try's is what they should get, unless past 50, or 75 ft, and then wait till next time. Maybe they had too big of a water jet in place, and flooded.
jlipskoc
Nov 27, 2008 08:41 PM
kw5.9
Nov 17, 2008 08:17 AM
goose2w1
Nov 20, 2007 09:06 PM
elk311
Aug 12, 2005 01:41 PM
y22man
May 12, 2005 02:41 PM
