Truck Pull June 30, Newland NC
Originally Posted by JDGPULLER
the blocks mean no solid blocked rear suspension. My 97 with OFE didnt make it down the track 1 time, but there may have been something wrong with it before hand not sure. Havent pulled since we put in the DD, and south bend didnt cut me any slack on the year old OFE, unless Tim can get him to do something, if you burn it it will be yours, actually it is already yours. The good thing about the OFE is that one side is metalic pucks so you will most likley be able to drive it home if it does burn up.
Tiger Rag,
Aren't you in or around Winston-Salem?
EastBend is just north west of winston salem and you could check one of their pulls out and then decide. Its very laid back sledpulling. They let some guy in a lifted F150 on 35" All terrains pull the sled with a stock manual tranny the other night.
Originally Posted by UnrulyNFS
Tiger Rag,
I was just thinking that I could hit the Newland pull on the way home from the OBX, but when I heard the rules on that one, I figured I was out, just didn't mention it. We'll have to get together and hit one of those. Mike D wants to do it too I believe. I also owe you my mini DV tape from Mopars at the Rock so you can edit it in.
Originally Posted by 35" 05'
yeah bud, ill probably be there on fri. is that the day you're goin? u should pull. if u pulled i would too prob. worse prob is the stick. 2nd gear low i guess not to burn my clutch. keep me posted on whos goin. id deffinatley be there.......DODGE POWER.....
And they did not have a nationals pull on Saturday night last year, it was rained out. They did have it on Friday night, however, and the only stock guy that pulled was a duramax that did pretty darn good, in the high 200s range. I dont know about the rules, since the stock pulls is after the nationals pull, I thought Newland was the judges on stock trucks.
Tiger,
I'll let you know next time I find a sled pull that I'm able to attend. Do the same if you go to one.
I also might make a trip out to newland on a mini vacation to watch out there sometime. I like getting away from work.
Originally Posted by jemery
The zip code is 27909. Here is a map of how to get to it: http://maps.yahoo.com/py/maps.py?Pyt...et+Map=Get+Map
Originally Posted by squirlchasr919
So what night is everyone going, fri or sat? I'm probably going on saturday, but might change my schedule if everyone is going fri.
I plan on being there. Just to see what it's all about. I've never been but the vids I've seen look like a lot of fun! What are the times for the show. I have about a 2 hr drive to get there.
