tractor pulling
Old Oct 15, 2008 | 12:16 AM
mopower01's Avatar
my injection pump is off of a 2670 case and the turbo off of a 4890 case. not for sure how big (mm) the turbo is but i will measure it on thursday. what kind and size bit did you use to drill out the injectors? and what size john deere pump is capable of 800cc?
Old Oct 16, 2008 | 06:45 PM
Tingram's Avatar
i am not for sure on the tips i will ask and find out, but just about any pump off of a jd can be built to go 800, but it is highly modified and there are only a couple of shops that can make them flow that much.
Old Oct 23, 2008 | 06:21 PM
mopower01's Avatar
we drilled out the injectors a considerable amount and there was no noticeable power change. the tractor ran smoother at higher rpms but that was it. i guess it will have to stay like this for the rest of the season. i havent pulled it yet like this. the last time it pulled it was only making 185 hp and it spun out in fourth high. now 1st we have a local pull so i guess i will see what is going to happen. im going for broke.
ckt_santiago
Dec 26, 2018 03:55 PM
JKM
Mar 10, 2006 10:17 AM
JKM
Aug 26, 2005 06:57 PM
JKM
Aug 26, 2005 08:28 AM
DieselDaze
Jun 10, 2003 07:36 AM
