St. Louis Dyno Pull - Special EVENT!!!!
Make your plans NOW!!!
When: Special 2-day event (Dec 1 & 2) 1st come 1st served
Where: MCS Midwest Performance Diesel (Located 2 exits West of Six Flags at the Gray Summit Exit on Hwy 44 - Off the South Access Rd - Turn back East 200yds and make the 1st right - MCS is on the Hill
Contact TN: 636-451-4144
When I say a Special Event,.. that's what this is. MCS in partnership with Van Aaken will put on this event. You must show up with NO power adders on your truck (remove your boxes and Downloaders). This event features the VA C5
Van Aaken is sending their Tech Engineer to St. Louis for this event. MCS will install a C5 on your truck. You will get 3 runs on their new Mustang "Dream Breaker" Dyno. The 1st run will be a baseline run with the C5factory setting. Then with a huge overhead you will be able to see each mouse click for user programming of the C5. The VA Tech will let you in on "how to" tuning procedures. He will then progressively tune your trucks performance up on the next two runs. When you leave this event, you will know how to tune your own truck.
This is a Walk-the-Walk event. You are not obligated to purchase anything. There will be C5s available at the event at a promotional price however.
This is a Special Dyno Event!!!
Get yourself scheduled NOW.
You must be prescheduled and prepayed for this event.!!!
Refreshments will be available as this will be a full 2-Day event.
Cost?
I believe I know what the charge is but I'd prefer you contact Keith at MCS for that at 636-451-4144.
I will say what you will be getting for your money is the Install/Uninstall and instruction of "how to" tune your truck with the software. To have a factory rep there for the instruction will be invaluable,.. this will be a great value.
Pricing for the VA Event
For the $100 you get the 3 runs on the dyno. You are also getting the unit installed and uninstalled. Also VA is sending their hot shot from the UK for this event and further you are learning how to do the tuning the right way. Think about it,... can you imagine how costly it would be to blunder through the tuning process with your major $$$$$$$$$$$$$ investment you have in your truck and all you've done to it to get to this point. IMO you can't afford to make a mistake. Learn to do this right. NO where in the country has this type of event happened,.. don't miss out.
It does not reset the key strokes. Anything is detectable, guys have been over this on other thread. I found out they are the hard way along with a friend. Most shop do not have the technology however if DC were to come in and tear into the ECM for a warrenty claim they felt was "different" you would be screwed, no matter how you cut it.
