Sled Pulling Questions!
Old Sep 12, 2005 | 07:23 PM
blackdiesel's Avatar
Registered
ok, the pulls are commin up in about a week so ive got a few questions. my hitch is right around 20 inches. do i need to raise or lower it? do i need front weights? how about blocking up the rear end? Thanks for the advice!
Old Sep 12, 2005 | 07:53 PM
djgaston's Avatar
We have different body styles but what I learned at the truck pull Saturday night is this...
My truck weighs 7,086 lbs. In our diesel class you can weigh all the way up to 8000 lbs. So yes, weights are good, and the more weight you have up front, the less the front will bounce. Mine was dribbling up and down like a basketball for a while until the track smoothed out a little. If you can't add plates up front, put some heavy stuff in your floorboard up front and then put the rest of the weight in the bed. Just try to get right around 7900 lbs.
As far as your hitch, I don't know what the legal height is... it varies from sled to sled. Find out and get yours as high as it can go. The higher it is, the more leverage you will have on the sled. Plus the rear will squat down once you get that weight in there, and the weight of the sled.
Air down your tires for a wider footprint. I do not know what to air down to but I know the other guys were doing it. I would guess 15 psi but even that might be too low for a heavy diesel... I'm new to the diesel world. :-)
Old Sep 12, 2005 | 08:07 PM
TxDiesel007's Avatar
max hitch height
26 inches... keep it as high as you can, its all i can help you with, well the launch you have a better clutch so third or fourth, build boost and launch in 4 low, and best of luck!!
Tx
Old Sep 12, 2005 | 08:19 PM
djgaston's Avatar
I launched in 4 low, 3rd gear and it was perfect for my setup... but there are a lot of differences between our trucks.
Old Sep 13, 2005 | 07:32 AM
Registered
so could i get a drop hitch and turn it upside down? will that be strong enough?
Old Sep 13, 2005 | 08:26 AM
I reinforced mine
But yes it should work out just fine, I have a pic in my gallery in which the hitch sits 22 inches above the ground with a 1 inch clevis hook... I have yanked out two stumps with it and no issues yet...
Tx
Old Sep 13, 2005 | 08:40 AM
Registered
ok, ill probley reinforce mine too. thanks tx
Old Sep 15, 2005 | 09:39 PM
Gwoody's Avatar
When and where is the pull going to be, who's sled, are they for sure gonna have a diesel class???
Thanks
Old Sep 15, 2005 | 09:42 PM
Gwoody's Avatar
Oh yeah, what's the weight limit????
Old Sep 15, 2005 | 09:44 PM
Gwoody's Avatar
Hey blackdiesel, there's a pull at Monett Mo. this Sat night @ 7:00, that's not too far from Omaha.
Old Sep 16, 2005 | 03:35 PM
Registered
sorry it took so long to get back to ya. The pull is Tuesday, in Harrison Arkansas at the North West Arkansas Distric Fair Grounds. i dunno nothin else about it except that itll be tuesday and yeah theve got a diesel class. Or they did last year anyways.....
Old Sep 16, 2005 | 04:25 PM
djgaston's Avatar
Harrison? I live an hour away from there... I live near Mtn Home. We should get together at one of the truck pulls! I work late Tuesday (get off at 11 PM) but there are other pulls coming up. There is one in Yellville on Oct 1st and I may or may not make that one. There are others. The Lady Luck Sled is the one that covers this area and I plan to follow them around.
Old Sep 16, 2005 | 09:17 PM
Gwoody's Avatar
Y'all are more than welcome to come to Monett Mo & pull with us Sat night @ 7, its at the Monett race track, 26 inch hitch height, 8500 lb. single turbo, no nitrous propane or water injection, run whatcha brung and hope ya brung enough. oh yeah no blocks in the rear springs
Old Sep 17, 2005 | 12:38 AM
AK RAM's Avatar
Question.....you guys that pull with an auto trans, do you lock your converter once you get going for better power transfer (mystery switch or other manual lock-up controller), or is trying to lock with that much weight behind you a no no?
Old Sep 17, 2005 | 09:48 AM
Gwoody's Avatar
I haven't yet, the problem is the TC won't lock at full throttle, not sure why, I know some that lock as soon as they leave the line at part throttle then shift through the gears, I'm just a little concerned about drive line shock when shifting with the convertor locked. The best would be shift through the gears then be able to lock the convertor. I'm not sure if all makes are this way but my DTT will not lock up at any more than part throttle.
