Quick question, Traction bars.
My Uncle can get me 2 types of tubing to make my traction bars. My choices are 2" pipe with 1/4" wall thickness or 2" solid bar. How would I make the solid work?
Well, I just figured that I'd weld a piece of tubing over the solid piece about 6" long on each end to accept the bushings & heim joints.
For a compression load a solid pipe will be much weaker, stick with the .250" wall, as long as its DOM and not welded. If its welded pipe don't even bother, you'll split it after too long. Solid is going to weigh a ton, and it will flex more than a good set of DOM bars.
O.T
26
May 3, 2008 09:37 AM
ckt_santiago
16
Apr 23, 2007 09:29 AM
JCLeary
Nov 16, 2006 07:21 PM
Nuttymopar
Sep 16, 2004 12:48 PM
