Pump work
Old Aug 7, 2006 | 01:19 PM
johnsjas's Avatar
Pump work
I have started to build a twin kit (S300 & S400) for my truck and now don't think I will have enough fuel. What are some good comp. to get a pump moded or what are some other options.
Old Aug 7, 2006 | 01:42 PM
wana12v's Avatar
well you could have it calibrated. but i think your best bet would be either buying a 215 cam to have installed in that pump, or I think you can buy a regrind cam from piers and then have your pump shop install it and calibrate your pump for max fuel. (should be able to squeeze 600 cc's)
Old Aug 7, 2006 | 01:51 PM
johnsjas's Avatar
What do the pumps usally run for cc's? Will the 600 make it undrivable on the street?
Old Aug 7, 2006 | 05:21 PM
wana12v's Avatar
I think a stock 913 (215hp) makes 260-280 cc's? not to sure exactly. mine made 465cc's with a 10 plate laser cut dv's and it was tuned and flowed on a bench with 17mm of rack travel. it will make more without a plate but it will retard timing internally (only 180's and 215's do this) 600 would probably be more than you would want on the street, butwith a valet it would be driveable however not exactly towable. but from the looks of your sig you already have it running 12's so i take it you probably aren't towing much?
Old Aug 7, 2006 | 05:45 PM
johnsjas's Avatar
Nope not towing just racing. I talked to Piers and quetioned them about there pumps but they said that I need a 913 pump before they will work on it. They don't want a 160hp pump as a core
I think that I will try to give schieds a call
cheese4420
Apr 13, 2008 11:50 AM
96_12V
Jul 7, 2005 11:26 PM
Moose10
Sep 1, 2004 06:01 PM
thumbs
Aug 5, 2003 06:57 AM
