Pulln Tires
Old Sep 1, 2007 | 01:18 AM
weldman05's Avatar
Exclamation Pulln Tires
I am gona pull for my first time tamarow night just wondering if i should leave the BFG Mud Terrains, or put my street tires back on. We have had no rain here and the track will be packed pretty tight, i just dont wana break anything. Also were should i run my juice WFO or not.
Old Sep 1, 2007 | 01:26 AM
PourinDiesel's Avatar
Run the MT's. Of course you should run wide open.
Old Sep 1, 2007 | 07:03 AM
JDGPULLER's Avatar
I know most prefer all terrains, but I go with the most aggressive I can get (this will get the most of your power on the track, but it will also help put your drive train to the acid test).
If your not willing to run all out there really is ant a reason to hook to the sled.
Good luck and as always be prepared for possible brakage
Old Sep 1, 2007 | 07:14 AM
NCYZ1V's Avatar
Run the MT's let MOST ALL of the air out...like 20 rear 35 front!
Donot forget your Pantyhose....P.M me for how to use that trick!
GOOD LUCK!!!
Old Sep 1, 2007 | 07:57 AM
jwb600's Avatar
not on the subject of tires but you might shut your overdrive off if you can. you might have already knew that but it worked well when I pulled my auto.
Old Sep 1, 2007 | 09:17 AM
blownsmoke2's Avatar
GOOD LUCK!!!
I air my front down to 25-28 but keep rear tires up to carry weight of sled also if the track is real dry and dusty the mud tires will help bite down into some better dirt.
Old Sep 1, 2007 | 09:18 AM
weldman05's Avatar
I was just wondering i figured with the street tires i could spin out easier and maybe not break as much stuff.
Old Sep 1, 2007 | 10:21 AM
JDGPULLER's Avatar
That is true but you don't want the embarrassment of doing nothing but spinning and not pulling, I always keep my rear tires aired up.
what is this panty hose stuff?
Old Sep 1, 2007 | 11:34 AM
1stGen545's Avatar
Traction in the rear is not a prob it has the sled pulling it down on the track. I run 40 in front and 65 in the rear with 295 BFG A/T's only becose I had 38x15.50's and the A/T's were half tread and $150 and I could put them on stock rims and still have my 38's ready to go for mud.
Old Sep 2, 2007 | 11:51 AM
weldman05's Avatar
Well i pulled last night i had to run on the 7500 open gas, diesel class i was a little out matched considering i was runing against guys with ladder bars and weight boxes. I will be ordering a new turbo and building a weight box this week IM HOOKED NOW!!!!!! By the way i pulled 260.5, finished 9th out of 18 trucks.
Old Sep 2, 2007 | 01:02 PM
jwb600's Avatar
thats not a bad pull. I only got about 226 ft when I pulled but I didnt run aggressive tires. get some ladder bars also they will help out alot
Old Sep 2, 2007 | 08:58 PM
There you go. Also I'm a firm believer that every time you pull and don't tear anything up its a good pull. I agree traction bars is a must then weights.
Good job.
Old Sep 2, 2007 | 11:07 PM
Iron Mike's Avatar
Weldman,
Which tires did you pull with?
Mike
Old Sep 3, 2007 | 11:51 AM
NCYZ1V's Avatar
I have won 5 years running and got 2nd in the PRO class....
ours is this month i will let y'all know how i do in a dodge?!
the tire prussere in the rear is so low due to its a dually.....
the Richmonders might read this so i will ony give out tricks like the pantyhose Trick by PM.
P.S. Great pull nothing broke it was a good PULL!!!!!
Old Sep 3, 2007 | 01:24 PM
weldman05's Avatar
Correction i placed 5th in the class, mike i pulled the BFG MT'S. Ready to pull again!!
