Pulling tonight
Old Sep 15, 2005 | 11:36 AM
CTD2001's Avatar
Pulling tonight
Well this morning i found out there were some local truck pulls at the county fair, so i think i am going to give it a go. I would like some advice from you guys as to how i should run. Should i run in 4LO with it locked in second gear? or should i put in in 4LO and leave it in drive with overdrive off? How should i launch? Build boost at the start? or just take off slowly and then roll into the go pedal? Thanks for any advice, i am a little bit nervous, and hopefully i wont break anything, Thanks
Old Sep 15, 2005 | 11:50 AM
PourinDiesel's Avatar
4Lo, leave it in drive OD off.
Old Sep 15, 2005 | 11:53 AM
cumminsdriver635's Avatar
I 2nd that. 4 low, overdrive off, in drive, and let it shift. I would power brake just a little to get a little boost on the line, and then once it starts building a little, and the chain is tight, and everything, drop the breaks, and lay the heammer down, and dont let out till you stop moving
Eric
Old Sep 15, 2005 | 11:54 AM
CTD2001's Avatar
ok thanks, should i take off slowly and then lay into it, or should i just mat it from a stand still? Thanks
Old Sep 15, 2005 | 11:55 AM
CTD2001's Avatar
Ok sounds good, that was how i was thinking about doing it, it should be fun, they have all of the gas jobs going first, then they have the diesels go
dodgemaniac
Competition / Pulls / OffRoad
18
Jul 6, 2009 10:36 AM
PADuallyBoy
Jun 25, 2009 08:19 AM
mullercarl
45
Mar 19, 2007 10:10 AM
doodah
Feb 11, 2003 12:19 PM
Shovelhead
Oct 5, 2002 10:48 AM
