Outlaw Drags and Sledpull May 12, 2007
Old Feb 7, 2007 | 12:31 AM
PourinDiesel's Avatar
2007 OUTLAW RACE AND PULL BOWLING GREEN, KY
MAY 11TH – OPEN HOUSE
MAY 12TH – DRAG RACING – BEECH BEND PARK -8:00 AM CST
MAY 12TH – DIESEL PULL –SOKY FAIR GROUNDS -6:30 PM CST
GATES OPEN AT 4:00 PM CST
TECHING AND SCALES OPEN AT 5:00 PM CST
TURBOS MUST BE TECHED AND TECH CARDS SIGNED OFF ON , BEFORE YOU WILL BE ABLE TO DRAW FOR PULLING POSITION , SO PLEASE GET THERE EARLY .
PULLING PAYOUT
Street Class - 500, 400, 300, 200, 100 $1500.00
Super Street -700, 600, 500, 400, 300 $2500.00
Open Class – 900, 800, 700, 600, 500 $3500.00
ADMISSION FEE - $10.00
HOOK FEE -$30.00
LOWREY BROS SLED
HOTELS
BEST WESTERN **OFFICAL HOTEL OF TS PERFORMANCE EVENT *** 270-782-3800 RATES 69.00 &79.00 POOLSIDE
ASK FOR KRIS SWEENEY TO GET RATE
COMFORT INN 270- 843-1163 RATES 79.88
ECONO LODGE 270-842-6730 RATES 59.95
DAYS INN 270-781-6470 RATES 59.95
RAMADA INN 270-781-3000 RATES 55.00
DIRECTIONS TO OUTLAW PULL
SPECTATORS
FROM I-65
TAKE EXIT 20 –NATCHER PKWY – (only goes west)
TO EXIT 7 – HWY 231 NORTH
GO NORTH ON HWY 231
TO NATIONAL GUARD ARMORY ON THE LEFT
TURN LEFT FOLLOW SIGNS
PULLERS
FROM I-65
GO NORTH ON HWY 231
TO FIRST LIGHT TURN LEFT ON HWY 880 (veterans memorial blvd)
TO HWY 2665 TURN RIGHT (glen lily road )
GO 6\10 OF MILE
GATE ON RIGHT SIDE OF ROAD
Rules for the Sledpull:
8500 LB STREET DIESEL TRUCK
1. Must be licensed, registered, and insured (Bring CURRENT registration and insurance with you to register)
2. Single Turbo charger only. Must bolt directly to manifold , NO adapter plates. The compressor housing may be no larger than a 2.4 inch inlet measured at the smallest diameter area of the compressor wheel. Downsizing of the compressor housing ahead of the wheel is NOT allowed but must meet the 2.4 inch diameter for at least 3/4 inch in front of the wheel along the bore. The inlet will be measured using a 2.45 inch plug. A stock MWE groove is allowed. No MWE groove will be allowed that has greater than a 1/4 inch width. All provisions allowing air to the wheel other than the bore and the MWE groove are prohibited.
3. Water\Methanol Injection allowed.
4. Nitrous and/or Propane are permitted.
5. All Computer chips and boxes are permitted
6. Stock appearing injection pump , LIMITED TO ONE.
7. There will be under hood inspections
8. Original style front and rear suspension. Lowering or raising vehicle height with suspension modifications is permitted. No Strapping or Chaining of Front or Rear Suspension. CenterLink maybe strapped.
9. Air Bags permitted, must have only 1 airline running to them and line must be capped off, no air tanks, compressors or in cab controls.
10. Tractions Bars must have a safety loop or strap securely attached to frame & bars near where bars attach to frame of truck.
11. Front Hanging Weights are allowed, NOT to exceed 60 inches forward of the center of the front axle. THIS WILL BE MEASURED FROM CENTER OF FRONT WHEELS .NO Weights in cab of truck.
12. Factory or commercially distributed aftermarket hitch. Must be horizontal to the ground and stationary in all directions. Height from ground must not exceed 26 “. Minimum 3 1/2-inch diameter for sled hook. (NO UNDER BED PULLING HITCHES)
13. Hook point must be past rear of truck bed.
14. NO hitches with chains holding it to a gooseneck ball or other device in truck bed.
15. Truck must have both front and rear bumper.
16. Driver must provide clevis, minimum 3 ½ “diameter.
17. No weight transfer hitches.
18. No chains, studs, spikes, etc.
19. D.O.T. Street legal tires.
20. Engine must have come stock from the factory in a 1-ton pickup truck or less application. Engine does have be an option by the same manufacturer as truck.
21. Drivetrain must be O.E.M. from 1 ton or less pickup. (I.E. NO DROP BOXES OR REVERSERS)
22. IT IS STRONGLY RECOMMENDED THAT ALL TRUCKS HAVE SAFETY EQUIPMENT (FUEL SHUT OFFS, KILL SWITCHES, SCATTER BLANKETS, DRIVE LINE LOOPS, FIRE EXTIGUSHER, ETC.)
8500 LB SUPER STREET DIESELS TRUCKS
1. May be hauled to pull.
2. Single Turbo charger only. The compressor housing may be no larger than a 2.8 inch inlet measured at the smallest diameter area of the compressor wheel. Downsizing of the compressor housing ahead of the wheel is allowed but must meet the 2.8 inch diameter for at least 3/4 inch in front of the wheel along the bore. The inlet will be measured using a 2.85 inch plug. A stock MWE groove is allowed. No MWE groove will be allowed that has greater than a 1/4 inch width. All provisions allowing air to the wheel other than the bore and the MWE groove are prohibited. ADAPTER PLATES ALLOWED.
3. All Computer chips and boxes are permitted
5. Water\Methanol Injection allowed.
6. There will be under hood inspections
7. Rear Suspension may be blocked. Blocks must be easily removed. NO WELDED REAR SUSPENSION.
8. Air Bags permitted, must have only 1 airline running to them and line must be capped off, no air tanks, compressors or in cab controls.
9. Tractions Bars must have a safety loop or strap securely attached to frame & bars near where bars attach to frame of truck.
10. Front Hanging Weights are allowed, NOT to exceed 60 inches forward of the center of the front axle. THIS WILL BE MEASURED FROM CENTER OF FRONT WHEELS 11. NO Weights in cab of truck.
12. Factory or commercially distributed aftermarkets hitch. Must be horizontal to the ground and stationary in all directions. Height from ground must not exceed 26 “. Minimum 3 1/2-inch diameter for sled hook. (NO UNDER BED PULLING HITCHES)
15. No weight transfer hitches.
16. No chains, studs, spikes, etc.
17. D.O.T. Street legal tires.
18. Engine must have come stock from the factory in a 1-ton pickup truck or less application. Engine does not have be the same manufacturer as truck. (i.e. Cummins Engine may be transplanted in a Ford or Chevy truck )
19. Drivetrain must be O.E.M. from 1 ton or less pickup. (I.E. NO DROP BOXES OR REVERSERS)
20. Trucks with manual transmissions, running in excess of 4000 rpms must run a scatter proof blanket on the bellhousing.
21. Rear axle bolts must be covered either by center cap or shield.
22. Drivers must wear seat belts & helmets are recommended.
23. IT IS STRONGLY RECOMMENDED THAT ALL TRUCKS HAVE SAFETY EQUIPMENT (FUEL SHUT OFFS, KILL SWITCHES, SCATTER BLANKETS, FIRE EXTIGUSHER, DRIVE LINE LOOPS , ETC.)
8500 LB OPEN DIESEL TRUCK
1. Trucks may be hauled to pull.
2. Truck doesn’t have to be licensed.
3. Staged Turbos are permitted.
5. Water\Methanol Injection permitted.
6. All Computer Chips and Boxes are permitted.
7. No Studded Tires or Tire Chains.
8. Hanging Weights / Weight Racks are permitted, NO weights in cab of truck.
9. Driver must provide Clevis minimum 3 ½ “.
10. The point of hook must be at least 48 inches from the centerline of the rear axle. Height from ground must not exceed 26 ”. Minimum 3 1/2-inch diameter for sled hook.
11. Trucks with manual transmissions, running in excess of 4000 rpms must run a scatter proof blanket on the bellhousing.
12. IT IS STRONGLY RECOMMENDED THAT ALL TRULY “OPEN” TRUCKS HAVE SAFETY EQUIPMENT (FUEL SHUT OFFS, KILL SWITCHES, SCATTER BLANKETS, FIRE EXTIGUSHER, DRIVE LINE LOOPS , ETC.)
Old Feb 7, 2007 | 12:32 AM
THIS IS GONNA BE BIG GUYS!!! SO COME OUT!
Payouts for the pulls are awesome (but I probably wont win anything )
Old Feb 7, 2007 | 12:45 AM
53 willys's Avatar
sounds fun, I wish they did more pulls around me (so I could go watch)
Old Feb 7, 2007 | 01:07 AM
jwb600's Avatar
you get those dual pumps put on and big injectors you should beat everybody around here justin. I dont think anybody will have a chance if you get it tuned in.
Old Feb 7, 2007 | 02:59 AM
Jesse, thats wishful thinking, thanks! Yeah I hope I do beat some people around here but I dont count on it.
I just hope to have a successful season like 06 and not break too much.
Old Feb 7, 2007 | 09:16 AM
House's Avatar
drugs allowed ***?????
Old Feb 7, 2007 | 09:22 AM
Yeah! you Powerstroke guys should be in heaven
Old Feb 7, 2007 | 09:32 AM
House's Avatar
lol naww i dont use them, i am not going , ill be in Stanford Ky the weekend before cant afford 2 weeks in a row
you havent heard the news? after this season my motors comming out and a common rail is going in place
Old Feb 7, 2007 | 07:07 PM
Howling's Avatar
House you have been saying this for the last few years.lol
Old Feb 7, 2007 | 07:22 PM
haloman's Avatar
I am planning on being there as a spectator
Old Feb 7, 2007 | 09:25 PM
House's Avatar
nope, truck will be finnaly paid off next winter, then i can play
Old Feb 8, 2007 | 01:34 AM
Kemble's Avatar
I will for sure be attending this fine event. I even get to celbrate my B-day on the 12th watching diesel drags . Too bad my truck isn't fast and won't pull a sled very well.
Old Feb 8, 2007 | 02:55 AM
JOHNBOY6.6's Avatar
This looks like a good warmup for Muncie!
Whats up 8500lbs? Dang thats 1800lbs of ballast on my truck.
Old Feb 8, 2007 | 08:30 AM
White00's Avatar
I'm in....the crowd that is. Hopefully I can get a bunch of my diesel head buddies to come down from IN too! I've alway wanted them to sled pull too, finally!
ADAM
Old Feb 8, 2007 | 01:16 PM
House's Avatar
Its Ky for you i love it! i can actually hang wieght!
