Need Help Might Pull Tomarrow
Old Aug 1, 2007 | 01:32 PM
CTD03's Avatar
Question Need Help Might Pull Tomarrow
ok i know you guys probably have answered this befor
but i want to pull and i am really thinking about doing it tomarrow
i have a big single disk in and i was wondering how to pull with it
i plan on doing this way
3rd gear low range
hold the throttle a little more than half throttle
let the clutch out while watching rear tire as soon as it starts to grab dump the clutch and hold on
or do it this way let clutch out let it grab and then hold it to the floor
any thing else?
what should i run my tst on i was thinking 6/5 and my pressure box on the middle setting?
Old Aug 1, 2007 | 02:56 PM
PourinDiesel's Avatar
Good luck.
Old Aug 1, 2007 | 04:00 PM
stuckey200224's Avatar
with a single disk i wouldent slip it mush at all or you will weld it all together
Old Aug 1, 2007 | 04:01 PM
J Lent's Avatar
I have pulled with single discs, but no matter what you do...you are gonna glaze the clutch somewhat. I wouldn't do it again with a single. The cost of the new clutch is usually 10 times greater than the money won for a first place pull. I pulled 286ft at Fayette county 2 years ago with a stock clutch & it cost me $1000 for a new clutch. Well...I guess the new clutch cost me $950. I won $50 for a 4th place pull that year. Just my $.02
Old Aug 1, 2007 | 04:07 PM
NCYZ1V's Avatar
I would go with 2nd gear Just me.... as for tid bits of tricks check you P.M.
Old Aug 1, 2007 | 04:54 PM
dieselJon's Avatar
If you watch my pull, I tried 3rd but couldn't get it moving. The clutch woulda slipped BAD if I didn't let up and try 2nd. Get some money set aside for a dual disk or just don't pull.
Jon
Old Aug 2, 2007 | 12:14 AM
JDGnut's Avatar
Jon
Just remember your gearing is different in your 1st gen... Your 3rd low is close to his 2nd high.. (he is in a 6sp 241 tcased 3rd gen.)
Jon... get the DD, and a little more smoke and hold her to the floor.. haha.. Good pull.. 1st gen's are just light.. throw some weight in...
Old Aug 2, 2007 | 12:46 AM
LUKE-MM-PULLER's Avatar
I use Low 3rd to pull. I bring the rpms up to 2K, then let the clutch out and push the go pedal down at the same time. I have a Luks single disc organic that has held up fine. It seems to hold better now than before I burned it a little bit at the first pull.
Old Aug 2, 2007 | 04:41 AM
CTD03's Avatar
i have a 5 speed 3rd gen its and S.O.
know i am looking at it as i better save up i dont want to put a new clutch in just yet. getting turbo and new power adders very soon
my clutch is a valair ceramic/ceramic
still if i go out slow and let the clutch grab how bad will that hurt it?
Old Aug 2, 2007 | 08:29 AM
CTD03's Avatar
Originally Posted by PourinDiesel
Good luck.
thanks i will need it
Old Aug 2, 2007 | 02:15 PM
You should be fine if you use common sense, and you know your truck pretty good.
dodgethis91cmns
Jan 23, 2011 08:22 AM
1992gen1_fan
Nov 23, 2010 07:33 PM
VisionxOrb
16
Feb 9, 2008 06:27 PM
Jordan5687
Jul 12, 2007 07:52 PM
tankeryanker
Apr 13, 2004 10:21 PM
