Houston, Raymonville, Missouri Pull This Weekend the 22nd
Old Sep 17, 2007 | 06:03 PM
Ground Shaker's Avatar
Originally Posted by CarcajouCummins
I would hope if you are allowing water, that it will be poured in at the track. Methanol is clear - just like water. I personally don't know why this one rule was changed. All the DHRA trucks running big fuel and tons of heat are not allowed to run it, so why change that one rule? There are a ton of trucks built to run DHRA rules and therefore are not set up to take advantage of water.
If they don't stop me before drinking it I think it will pass (that and if I'm running to the crapper half way through the pulls). There was about an hr conversation between Corey, Darren and I at Mtn Home 2 weekends ago and we figured that was the easiest way to do it. There was alot of disscussion on the subject and with the water we felt it would be right. The water/meth combo is a major combo for cooling and although some trucks might need the cooling we felt that if someone was runnin to much meth they would just run away from the rest of them. The cooling will help the drivers know the EGTs will stay in check and not have to worry about picking up pieces going down the track. If enough big trucks show up that want to run that combo then Corey said there maybe another class but you'd have to ask him. Either way its going to be a matter of who is there. Corey and them are hoping for a big pull and if that happens and the trucks show up god only knows what the purse may get up to and what classes after that they may have. Matt, might you be amoung the people there?
Old Sep 17, 2007 | 06:14 PM
CarcajouCummins's Avatar
I have been planning to go, but it depends on where everyone else goes. With the allowance of water in the Street class, they may end up going to one of the other pulls around. If I end up going down to this pull, I will look you up.
Old Sep 17, 2007 | 07:08 PM
So you think we should outlaw it?
Old Sep 18, 2007 | 07:28 AM
HOOKED's Avatar
Not tryin to be a thorn but i meet all the DHRA rules and if they are going to be changed (allowing water). I may pass on this pull. There are plunty of "BS" associations around here that have changed the rules and ruined the class...I have a pump that will melt the entire motor down but i dont run water... Thats part of pulling... Meet the rules or dont pull... Im sure if i dont go it wouldnt hurt anyones feelings but you guys are asking so i figured i would let you know where i stand...
Old Sep 18, 2007 | 09:22 AM
perkins's Avatar
HOOKED is wright need to stick to one set of rules don,t change things for just to let a few get into a class.
Old Sep 18, 2007 | 09:24 AM
I called some of the guys up here, and they are going elsewhere this weekend as of now. I don't think any of them are completely against going to Houston, they just prefer to run within the normal rules. If there were not other pulls then they would be at Houston, but the KC pull is paying pretty good and most of them are heading that direction.
Old Sep 18, 2007 | 10:14 AM
satburn's Avatar
Just so you're aware, Lathrop is using NWMTPA rules...
Rule #23 from their Diesel Truck Class:
23. Water injection is allowed. Water ONLY, no alcohols, or other foreign substance additives. A pump lube may be used.
Old Sep 18, 2007 | 10:54 AM
HOOKED's Avatar
But they havent changed rules... That is the point we are trying to make. Posting rule changes 4 days before the pull isnt a good idea.
POSTED BY COREYDR2003
Diesel Trucks Wanted Sled Pull Near Houston Mo
Hi everyone,I'm new to the site and I wanted to let all you fellow sled pullers know that I'm holding one of the biggist pay out pulls of the year if not the biggist. Fun starts at 5:30 p.m. September 22 nd @ Raymondville Mo, Classes include:
C.M.P.A. (Tri-State)
Modified 4x4 $2000.00 pay out
Pro Stock 4x4 $1100.00 pay out
Diesels Classes Will be D.H.R.A. rules with a 8500 lb limit
Street Diesel
Work Stock Diesel
These two classes will split a $2000.00 purse $1000.00 a class.Expect added money.
There will also be a hometown Diesel class open to all stock trucks.
P.s. If you have any questions drop me a line @stephanie168@centurytel.net
Thanks
Quote:
Originally Posted by satburn
Alright, then we'll simplify things in one post.
Houston Pull
DHRA Rules (Street Diesel - Work Stock)
http://www.dhraonline.com/main/forms...ook-v2.7.1.pdf
See your class section for details
No Ag Governors in Street Diesel Class (May offer a Super Street / Open Class for Ag Governors if enough show)
No Helmet or Fire Suit Needed
No Air Shutoffs Needed
Plates Required for Street Diesel Class
4,500 rpm Rule (Puller must provide proof of RPMs if questioned, otherwise prize money will be forfeited)
Drive shaft loops, Upward exhaust, Cross bolts in exhaust & Fire extinguisher waived for first time pullers, but suggested for safety.
No 2.5 turbos in Work Stock Class
We will weigh you in check your hitch and look a few things under the hood. Afterwards will take the top five and tech them again, everyone will need to stay in a single file line to the end of each event no work will be done. I will have my staff to watch these trucks.
Old Sep 18, 2007 | 11:24 AM
satburn's Avatar
I guess I was missing the point, yes, changing rules only leads to confusion and I agree adding a Super Street rule to a Street Diesel rule set the week of the pull is something I wouldn't suggest (nor did I).
The point I thought you were making was that the KC pull was running DHRA rules (no water) and you wanted to go there for that reason. I'm sorry, I see where you are coming from now.
Old Sep 18, 2007 | 11:52 AM
HOOKED's Avatar
I should have been more informative with my post. Sorry Satburn. The ONLY reason i was willing to drive 3 hours away is because of the rules in place... I can drive to Jeff City and hour and a half away and pull a brush pull which is what this thing will turn into they arent carefull... Heck Satburn we need to spend all winter building a sled and for the paint job the rules will be painted on the side! The only way they will change is if someone runs into it...
Old Sep 18, 2007 | 01:35 PM
I think it has more to do with distance. Since Houston is not running DHRA rules, they are going to a closer pull.
Old Sep 18, 2007 | 01:42 PM
satburn's Avatar
I see, gotcha.
Old Sep 18, 2007 | 04:00 PM
OK here is the deal. I called up the people that I am bringing. None are using water. Matt said none of his were using water. So there is NO water (I changed the rules in the previous post). All the other rules are straight out of the DHRA hand book. The only things we changed are the weight break (8500 in case a duallie wants to play) and a couple other minor things. The main things changed had to do with bellhousing blankets adn what not. I did change the OEM bed as if someone comes in with a flatbed and it is a work truck then they would be allowed, but everything is just pretty much right out of the DHRA handbook now.
Old Sep 18, 2007 | 09:50 PM
Thats cool, I will spread the word that rules are DHRA and final.
Old Sep 18, 2007 | 10:22 PM
Dullydiesel's Avatar
What is the hang up with straight water???? Lets face it we have a lot of money in our trucks.........just wondering.........
